Question about Dryers
Kenmore series 70 gas dryer no heat, where is the glow plug located and how do I get to it?
    Genius:
  • 2,920 Answers
Its a heating element and its in the back of the dryer...it could also be the limit switches that are bad they are at each end of the heating element. you have to take it out of the dryer and replace it
Posted on Jan 29, 2009
Kenmore 70 series dryer starts and heats up then shuts off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 02, 2010 | Kenmore 73952 Gas Dryer
The dryer won't light 70 series Kenmore (gas)
heatman101
Aug 08, 2010 | Kenmore 700 6972 Dryer
My kenmore dryer series 70 is not heating, i replaced igniter, thermo sensor, and still does not heat....there is no glow from inside please help....
Check the fuse Note: Gas dryer thermofuse is linked to the gas assembly and blows whenever the temp exceeds 350f rapidly. Remove all air restrictions15f9d55.jpgbefore replacing that fuse or you will just need to keep buying em.f8e11bb.jpg65c991e.jpg
May 08, 2010 | Kenmore 62602 Electric Dryer
Kenmore 70 series gas dryer does not ignite I chenge the coil still not heating
Check for burnt out glow ignitor. If okay then check thermal fuse and all other thermostats with ohm meter..... all must be in closed position.
Mar 21, 2010 | Kenmore 73952 Gas Dryer
Kenmore gas 70 series dryer not heating up..
you'll need a meter,check the ignitor, and the sensor,if these are good you have bad gas coils or gas valve,come back with full model number and check to see if ignitor is glowing
Nov 07, 2009 | Kenmore Dryers
Kenmore 80 series gas dryer has not heat
most of these dryers have a little plastic plug on the front, left side. pop that plug out and look inside after turning it on. you should see a red glow. if not, then your ignitor has broken. if you see a glow, then the problem is probably one of the two little coils on the gas valve. these coils will sense if there is something to light the gas [the red glow] and open the valve - if the coils are bad, they won't open the valve
Aug 17, 2009 | Kenmore Dryers
Kenmore dryer not heating
Check the following-- Gas valve coils Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Jun 05, 2009 | Kenmore Dryers
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Heating on series 70 Kenmore Gas Dryer
suspect the 2 black coils on gas valve/burner after first heat cycle they will open and not work until cool down
Nov 26, 2008 | Kenmore 70172 Gas Commercial Dryer
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
103 people viewed this question
Top Dryers Experts
