Question about Canon PIXMA MP170 All-In-One InkJet Printer
Ink problems col vol unknown and wont print
Hello.. my name is Scott and i have a problem with my printer .. it is a Canon MP170 and i have had it for about 12 months. the first time i replaced the INK with a non gen colour ink it came up with a error saying nged it and now it has a UNKNOWN Error on the Printer screen saying: U051 and BLK INK VOL UNKNOWN & COL INK VOL UNKNOWN.. I have a brand new gen canon black ink. if someone can give me steps to fix this problem that will be GREAT.. i was told there was a INK Reset button or something like that once you got new ink you are meant to press RESET or something i have no idea what that is meaning. please email me on [email protected] with helps for this ASAP! thank you very much Scott
  • Scott Weston Jan 16, 2008
    Hello Marcus
    I couldn't find a way to turn off the colour monitor either.
    I replaced my colour ink with gen and turned the printer on and off a couple of times and then it fixed itself.
    I don't know how I / it fixed itself but it works fine now.
    Sorry this isn't muck help
    Scott
Something that worked for me, I opened the Conon MX310. took out both cartridges, and for 10 seconds I held the Reset. put the cartridges back in, closed the lid, and again, for another 10 seconds held the reset. SLOW seconds. this reset, ink levels recognised,, and it's working as it should be.
Regards
Shane (AKA Reef_Lex)
Posted on May 26, 2009
  • Bem Maria Mar 01, 2012
    This suggestion doesn't work people, don't waste your time.
How do you turn off the ink status monitor????????? I've been through the entire array of "Menu" options and there is nothing apparent. I have the same "col vol unknown" error, but I'm using a real Canon printer cartridge. Needless to say, I'm frustrated beyond compare.
Posted on Jan 16, 2008
  • 98 Answers
Turn off the ink status monitor. You'll know it's time to refill again when your printing starts to fade, streak, or discolour. It seems like there in no way to reset the ink levels.
Posted on Jul 27, 2007
SOURCE:
COL INK VOL UNKNOWN
Hello Poshpink,
take out both cartridges, and for 10 seconds held the Reset. put the cartridges back in, closed the lid, and again, for another 10 seconds held the reset. SLOW seconds. this reset, ink levels recognised,, and it's working as it should be.
thanks.
Sep 06, 2011 | Office Equipment & Supplies
Canon printer pixma mx310 will print but will not make a copy. It gives message "col ink vol inknown"
> col ink vol in known
The amount of INK in the COLOUR cartridge is not KNOWN.
Replace the COLOUR ink-cartridge.
May 22, 2011 | Canon PIXMA MX310 All-In-One Printer
When changing ink cartridge on canon pixma mp170 coming up black in volume unknown any solusions?
check the number on your ink cartridge. for black it can be the #'s 40 or 50. for color it is 41 or 51. if this doesn't help I'm sorry but i tried. I hope this helps
Feb 15, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Cannon MP220 displays colour ink vol unknown
For the Canon Pixma MP220, I kept getting a message saying "Col Ink Vol Unknown" after refilling and replacing a cartridge. After reading some of the other responses it appears as though Canon cartridges contain internal chips that prevent you from using them after they have been refilled. However, I tried a few things and this is what worked for me.
1. Insert your refilled Canon cartridge like normal, close the lid.
2. The Error message "Col Ink Vol Unknown" should still appear.
3. Use the "Menu" button to scroll to "Maintenance" (press "Menu" 8 times to find it), then press "OK" to conduct a "Nozzle Check" and a coloured test will print out.
4. The Error message will still appear but you will be able to print using colour AND with black and white. For some silly reason the Canon Pixma MP220 won't print using black and white if there is no coloured ink...
Hope this helps!
Feb 03, 2010 | Canon Office Equipment & Supplies
Ink Low message after installing new cartridge
There is no way to actually "reset" the counter. IF your MP170 has a RESUME/CANCEL button, Press and hold this button for about 7 seconds to bypass the counter (The PAGE FEED button will work for some other models). If your printer doesn’t have this button, you may bypass the counter by turning the printer OFF. Now hold down the RESET and turn the printer ON. Keep holding the RESET until the printer boots and initializes. When the display says, "INK VOL UNKNOWN" you may release the RESET and begin printing in the usual manner. You may need to start the printer in this manner each time, or the printer may remember this setting. Canon was experimenting during this time so some of the same models have different buttons and bypass tricks. Hope this helps.
I hope this helps you.
Sep 13, 2009 | Canon PIXMA MP170 All-In-One InkJet...
MESSAGE 'CHECK INK U051 BLK COL'
just hold down the stop reset button for 10 seconds it will bypass the ink counter
Jun 05, 2009 | Canon PIXMA MP170 All-In-One InkJet...
COL INK VOLUME UNKNOWN MESSAGE
Regards
Jan 03, 2009 | Canon PIXMA MX310 All-In-One Printer
Waste ink tank full error 5b00
Check out:
http://www.fixyourownprinter.com/forums/inkjet/50418#1
May 01, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Canon MP180 Ink Problem
lads ye're all I work in an 'ink place' and the u051 fault is a fault indicating that the offending cartridge is electrically dead, this is caused by the clever little program in the canon machine that writes info to the cartridge to make it'dead' so it cant be re-used ! possible solution is to get refilled before printer thinks it empty !!
Feb 09, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA MP170 All-In-One InkJet Printer Logo
3,340 people viewed this question
Clive
Clive
old marine
old marine
Ekse
