Question about JVC AV27WF36 TV
Image doubled when using 480p
I tried getting a 480p image from my JVC I'ART AV-27WF36 television, but when the progressive scan signal was sent, the picture was doubled, split half-way down the screen. I'm using component cables in the component input. I figured this TV supported progressive scan since it has component inputs, but now I'm not entirely sure. Does this TV model actually support 480p?
No it is only 480i with component cable support.
Posted on Jul 01, 2008
SOURCE:
I have older projection JVC i Art pro Tv, it is projecting a double image and i need to know how to fix it easily
if model number is correct the two stk-392-110 chips need to be replaced.
Can you solder?
see photos of board in your set and I can tell you how to get it out and what is needed.
Before you rate this information let me know if you can solder etc.
Jul 25, 2011 | JVC AV-56WP74 56" Rear Projection...
Pantalla
Classic sign of failed convergence. You can get the JVC AV48WP74 Convergence repair kit from www.tvrepairworld.com which contains the two IC's and associated resistors plus has the CD with detailed repair instructions.
Jul 20, 2010 | JVC AV-48WP74 48" Rear Projection...
Component resolution why does it not want to do 480p
480p is used in LCD TVs to make the image look less pixelated. You have a CRT which doesn't support progressive scan
Feb 27, 2010 | RCA TruFlat 27F520T 27" TV
Blured/ double image
blue/red convergance offset, double image
Jul 07, 2009 | JVC AV-48WP30 48" Rear Projection...
Double image
In all probability you need to have the convergence amplifiers replaced. A very common problem with all projection sets.
Jun 02, 2009 | JVC AV-48WP74 48" Rear Projection...
Sony KV-32FS12 Component Video 4 Has A Wavy Picture
sounds to me like the differnence between watchiing in progressive and interlace. these older tube tv's are not capable of displaying a progressive scanned image. like the first dvd players. check your video out settings on your ipod to make sure its an interlace output.
Apr 23, 2009 | Sony KV-32FS12 32" TV
NO HIGH DEFINITION
  • HDTV capable: Yes (up to EDTV, 480p)
  • Jul 10, 2008 | Akai PT5492S 54" Rear Projection...
    CVI connection
    On a Philips TV the only way I know to switch to any of the inputs is by scanning using channel up or down. This model is capabable of 480P input only at the CVI/Component input. This is not a HD television. It is only a EDTV (enhanced definition) if you try and input anything iver 480P IE: 720p or 1080i, the double image and/or lines is what you will get.
    May 27, 2008 | Philips 27PT8302 27" TV
    High Def.
    If you are using the component inputs it will select 1080i automatically IF that is what it is being sent. Make sure your device (cable/satellite receiver) is set to 1080i. The TV recognizes 480i, 480p(progressive scan DVD player) and 1080i. It DOES NOT recognize 720p. Since it has no HDMI or DVI input it can't do HD DVD or "upconvert" DVD but it does very nicely with 480p/progressive scan.
    Dec 24, 2007 | Mitsubishi WS-65311 65" Rear Projection...
    Televison & Video Logo
    424 people viewed this question
    Top JVC Televison & Video Experts
    Jaime Hernandez
    matt martin
    matt martin
    Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
