Question about Cuisinart DLC-5 Food Processor
Jammed cutting blade in cuisinart tube
I have managed to jam a cutting blade into my cuisinart's hollow plastic tube and cannot remove it.
Can you help?
  • 36 Answers
Try immersing the tube in super hot water. The plastic might expand just enough to let you slip out the blade. Since the tube is dishwasher safe, there should be no harm. A little soap in the water might help it slip out.
Posted on Jan 30, 2009
Cuisinart smartpower duet BFP703 food processor repair manual
Oh some of these answers... the most common issue with blender is that the removable blade unit starts to jam. So :
1. unscrew it, clean it and make sure it turns easy
2. open the unit and replace the fuse that blew up because turning the blade became too hard.
Nov 25, 2012 | Cuisinart BFP-703 SmartPower Duet Food...
Food processor blade stuck on motor shaft
my friend if you had not removed that blade for a while it will certainly stuck due to the moisture that forms on the shaft of the blade holder causing it to have corosion you will have to carry that item to be removed by a qualified tech by you doing it your self could cause damage,which could cost you more.good luck
Jun 16, 2007 | Cuisinart DLC-5 Food Processor
Locked in blade
My old Cuisinart has this problem because the motor shaft and the corresponding socket on the cutter are worn. The shaft has jammed in the cutter. To un-jam it, stick a bar of wood behind one blade of the cutter (I use the wood handle of my dough whisk) and give it a light, sharp tap with a hammer. Check after every tap to see if it is loose, if not do it again. You want to tap against the back side of the cutter, not the cutting edge side. The socket on your cutter may be cracked, allowing it to open up and slip (and jam) under the stress of cutting. You'll probably need a new one. If the motor shaft is also worn, that can also be replaced. The new part is about $10. I got a few more months of life from my cutter by reinforcing the inner socket with a thin plastic tube from the barrel of a syringe.
May 15, 2010 | Cuisinart DLC-5 Food Processor
I need to remove the plastic motor shaft sleeve from my Cuisinart DLC10. THe old one cracked, I have a new one but the old one won't slide off...
Many people have had this problem. When I called Cuisinart, they said, oh sure we will send you the part and instructions. When I called because there were no instructions, I got another story about how I needed to send it back because that repair is only made at the warehouse. I have found other places online where people just chip and pick at the plastic until it comes off. Short of sending it back and paying the shipping I don't know what else to say. My husband is chipping and picking as we speak.
Jan 02, 2010 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DLC-7--blade stuck--cannot remove from bowl.
First off, is it a BLADE that's stuck, or a DISC?
If it's a disc, and the disc is blocking your access to the center post, put a ziploc baggie full of ice on top of the disc (right in the middle) and let it sit for about half an hour. That should shrink the plastic enough to pop it out.
If it's a blade, you can try the ice trick, or you can try Pam (or another food grade cooking spray) to loosen it up, and then just try to take the workbowl off like you usually would (aka, DO NOT grab the blade, or you'll risk cutting yourself--you can just pull up on the bowl, and the blade should pop off.
If you need further help, you can always contact Cuisinart--their phone number (according to their website, ) is 1 800 726 0190
Good luck! :)
Aug 31, 2009 | Food Processors
Food processor does not work but light is on
Put the work bowl, lid, and pusher on one piece at a time - handle of work bowl faces the front of the food processor, hollow feed tube faces the back, and the sliding lock switch on pusher sleeve faces the front. Should turn on.
If it doesn't, test the motor - remove the work bowl and other parts completely. Plug the base in and turn it on, and use a pen to push in the dark grey or black button on top of the base - if it spins, the motor is still good - you may just need a replacement part. If it doesn't make a sound, it needs to be sent in to Cuisinart for repair.
Mar 29, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DL 11: Cracked plastic drive shaft
If it is in warranty, it can be sent to Cuisinart for repair. If it is out-of-warranty, it will cost more than a new food processor to repair.
Dec 11, 2008 | Cuisinart DFP-11 Deluxe Food Processor
Stuck dough blade
On the DLC 7 Pro cuisinart the blade was removed by removing
the plastic bottom. Make sure the unit is unplugged. Remove the four rubber pads on the bottom. This was the hardest part because the pads are glued so securely that the inner rubber surface tears as it's removed. I used two flat blade screwdrivers and worked carefully, back and forth. Using a #2 philips, remove the four screws. Place the unit on its side and while inserting a screwdriver between a spoke and the motor frame gently turn the blade counter clockwise. Be careful not to put pressure against the cooling fins. Very little pressure was needed and the blade came right out. I might have been able to hold the shaft from turning without removing the bottom, by going through the vent slots in the bottom, but I was concerned with cracking the plastic. To replace the rubber pads I matched the design of the torn rubber pad with the shape (design) of the surface glued rubber and used thin two-sided tape.
Dec 27, 2007 | Cuisinart DLC-5 Food Processor
Jammed Blade
Had the same problem. The Cuisinart folks said to fill it with hot tap water - not boiling - then turn it on and off. The heat from the water will unstick the bowl. If it doesn't work first time - refill with hot water and try again. Worked like a charm for me.
Nov 28, 2006 | Cuisinart DLC-XP Plus 20 Cups Food...
Cuisinart DLC-5 Food Processor Logo
174 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
