Question about GE Profile JVB67H Kitchen Hood
How to replace up/down switch in downdraft vent for cooktop
We have a downdraft cooktop vent that has a down (when not in use) and up (when in use) position. After my wife, put cleaning solution on the up/down switch, the vent remains in the "up" position. The blower, however, works fine. I am guessing that the cleaning solution shorted out the switch. I bought another switch, but alas, I cannot figure out how to get into the housing to replace the existing switch! Can you help me with step by step ideas about how to get into the housing and "switch out" the switches? Thank you for your time and help. Re: GE 30" Downdraft Vent Model JVB94SH1SS
  • Guitarstar Dec 06, 2008
    My switch came loose and shorted on the surrounding metal. I think my control board got zapped, its p/n 959-0138-003. I'd like the take the switch off too, but can't see how.
    New Friend:
Does any body know where I can get the schematic for the PC Board P/N 959-0138-003 by ACT, Inc.?
Thank you.
Posted on Dec 30, 2013
2 Suggested Answers
SOURCE:
SOURCE: JVB37H1BB downdraft ventilation system stuck
Folks, I have experienced the same problem several times - in all of my cases the problem was solved by simply opening the back panel and taking out the motor assembly and re-aligning it. Check out this URL for a blow up of what's inside and parts list - http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130126
The problem is that the arm tends to slip out and therefore won't raise or lower the hood anymore. Be careful when aligning it can be a little tricky - carefully observe the how the motor works outside of the housing via the switch and you will get the idea.
Posted on Sep 01, 2011
Whirlpool SC8720EDB cooktop stove independent vent switch is not starting downdraft exhaust fan, but the exhaust fan works fine when left side burners were turned on
Can you get to the switch terminals and try jumping them out with a piece of insulated wire? That would tell you if the switch is defective (my suspicion). Please be careful not to touch any live terminals - only the wire insulation you use for the jumper.
Aug 02, 2017 | Whirlpool Cooktops
Downdraft ventilator has stopped working
We have a Viking VIPR101 30" downdraft ventilator. We've learned that the ON-OFF switch on the side of the ventilator can overheat and burn out when it is held down continuously (poor design). Best to push and quickly release it. First time we had the switch professionally replaced--it's modular and very simple to swap out. Next time we fixed it ourselves with switch part # PV300182 from allvikingparts.com. They had replacement guidance on-line. Hope this is useful.
Mar 17, 2015 | Viking VGRT360-6B 36 in. Gas Cooktop
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
The motor in our Jenn-Air central downdraft has stopped working. It's an electric cooktop. We think it's time to replace the unit; want to keep the central downdraft format, but this time want to have...
Not a problem . take a look at Jenn-air 's dual fuel . gas top elect oven and also down draft unit . can be vented several way's .. mm hope this helps . feed back pls . 84020
Dec 21, 2009 | Ovens
My new home already has a hood vent for the range. I have a gas Jenn air downdraft range. I prefer to use the hood vent as the downdraft is not very efficient. Do I have to connect the blower on my range...
The poupose of either is to eliminate any smoke created by the range or grille and move as much of the cooking odors to the outside. I wouldn't use both at the same time, but if the hood is vented to the outside, it would be just fine to use only the hood. Aregular cleaning will be necesssary. The downdraft has limits as to the distance it will efficiently exhaust air. Flex hose should not be used. And excessive bends or vent length, cuts into the efficiency.
Oct 29, 2009 | Jenn-Air JED8230 Electric Cooktop
Installing JED8230ADB Cooktop Grill with down-draft exhaust
I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
Feb 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Thermador cook top with down draft ventalation
I would think you can. Most of the cooktops are 240v and the vents are 120v, so the vent may be feeding off of one of the cooktop's hot wires. My vent is fed from it's own receptacle but is harnessed along with the cooktop's 240v.
Oct 31, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
GE Profile JVB67H Kitchen Hood Logo
1,600 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
