Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Just wated to know if i pour the liquid in the water or over lit where there some space...i have the bissell power steamer deluxe w/the dirt lifter power brush and have never use it...thanks for your help
  • 360 Answers
This link is for the Power Steamer User Guide.
http://www.bissell.com/images/UserGuides/1697_207.pdf
Hope this helps.
Please take the time to rate this solution.
Posted on Jan 29, 2009
My power steamer model 1697, 8804 series doesn't **** up the water
I filled up my Bissel power steamer with hot water. I also filled up the formula mix. It turns on and sprays. The "dirty" water was seen the first time I used it. Now there the clean water is on the carpet and no dirty water is in the tank what"s up???
Jan 01, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
Water line routing
The biggest prob with Bissel is not pumping soap. Becuase if you don't run hot water through this tank the soap will dry and clog after cleaning and storing. Before taking it apart try running hot water through the solution tank and help break up the residue, best of luck. Steve
Jun 06, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
My power steamer will not squirt water. Seems to
it migh be that the formula you mixed together is notcreating enough pressure to force the mixture out is it the formula the company sells or did you pick up some other formula
Jul 10, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
How to put automix piston back in place of a Bissell Power Steame
Called the Bissell Power Steamer customer service number and the CSR explained how to turn the water control knob counterclockwise 260 degrees until the automix piston grabbed hold. Worked like a charm. Thank you Bissell company.
Jun 18, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Lost manual
Hi!  You can download the manual from www.bissell.com Click on the Customer Service tab, then in the next window click on the User Guides link on the left hand side of the screen.  You can then enter your model number and all will be revealed. Good luck!  If this is helpful please remember to rate my response.
Feb 24, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell Power Steamer Pro
The belt has broken and needs replaced. bissell uses a belt driven pump. ther ar two belts, one for the brush, and one for the pump. all can be replaced through the belt access on the left hand side of the machine.
Nov 05, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1697W power steamer
I JUST PURCHASED A NEW BISSELL CARPET CLEANER AND THERES NO INSTRUCTIONS IN MY BOOK AS TO HOW MUCH CLEANER TO USE, IT SAYS ON THE BOTTLE OF CLEANER THAT CAME WITH IT,IT SAYS TO ADD 5OZ.OF CLEANER TO EACH GALLON OF HOT TAP WATER
Apr 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
135 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
