Question about Watches
I don't know how to remove the links.
I just bought this watch online, and I received and it is too big for me, how do I remove the links so I can wear it? There are no markings on the pins to show which way to push out.
  • 2,334 Answers
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 31, 2009
How do I take out a couple links in the band of a 7056 White Peugeot watch. The pins are not spring loaded like most other watches. The band is plastic and there is only one pin per link. I don't know if...
Hi I just bought this watch for my wife's birthday and we had the same problem, it was too big. I googled and binged for a solution to shortening the band or to remove a link but no one had an answer. I go crazy with things like these and just decided to look at the watch band. First took out the pin for the latch so I can get a better look because that pin can be pressed down. On the inside of the band are arrows. Those arrows indicate which direction the pins can be pushed out. Just push the pin out with a tool, they will require a little pressure but they will give because one end of the pin is bigger than the other. Remove link and enjoy. Hope this helps someone else out there. Just a note this is only for the Peugot 7056 it has a white plastic band and I wouldn't recommend anyone try this with any other model as I don't know how those bands are designed.
Dec 30, 2010 | Peugeot Watches
I bought a Callaway CY2130 golf watch and its too big. I cannot figure out how to remove a link to make it fit.
at the sides of the stainless steel bracelet near the lock you will see holes its a small screw, use a small screw for this. just be careful with your hand.
Dec 13, 2010 | Callaway Quartz Golf Watch
I just received a new Kenneth Cole watch model KC4646 and the band is too big - I need to remove 2 links - but have no idea how to do this? Help!
Thanks for contacting FixYa.<br /> You can find a simple tuturial here:<br /> <a href="http://www.webwatches.co.uk/how_to.htm">http://www.webwatches.co.uk/how_to.htm</a><br /> <b>Best regards. Jewel</b>
Aug 26, 2010 | Kenneth Cole 1213 Wrist Watch
I am trying to remove 2 links from a ladies indiglo watchband
mcdevito75 here, To remove the links from any watch band requires a special tool called a Link Remover tool, available on ebay. You can remove the links without the tool but the time and work, just isn"t worthit, even with the tool if you don"t know anything about watches, your best bet would be to look for a small watch repair shop in your area , and have them remove the links, hold onto these links in case you need to ever replace them.
Aug 26, 2010 | Timex 2J611 Watch
Remove links on this watch
Most bands have removable links on the end of the band. You can tell because they have small holes on the side to remove the pins that hold them together. The links that don't have holes are not removable. This is standard on most metal bands.
May 09, 2009 | Timex Atlantis 100 77517 Wrist Watch
Minicci sport watch problem...
I also have this problem and how do you remove the links? it's too big for my hand.
Dec 26, 2007 | Kenneth Cole RK5034 REACTION
Armitron mens watch band link removal
Try http://www.webjeweller.com/jewellery/removelinks.shtml
Dec 25, 2007 | Watches
Watches Logo
509 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
