Back to:
Tags:
IBM 6400 Model i10 Matrix Printer
IBM 6400 model i10 print problem
posted by naldzki on Jul 27, 2007
Hi all,
Have you experience printing in IBM 6400-i10 that the 2-3 characters at the left side margin being cut-off in printout.
I had tried some troubleshooting already like adjust the tractor margin, restore from old configuration etc. but still not successful.
Thanks for your kind attention.
Comment by naldzki, posted on Jul 28, 2007
Only bottom margins is there no left and right margin settings. Please send me email directly : naldzh@yahoo.com Thanks.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 27, 2007
Thanks for Trying (70)
dpanda
Rank:Apprentice Apprentice
Rating: 65%, 3 votes
You might want to go the printer properties and look for a option called gutter. Increase the value of this setting. This tells you the distance that should be left on the left side margin.
Rating Locked! (?) naldzki has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on IBM 6400 model i10 print problem:
I don't want to Accept this solution
Solution #2
posted on Jul 25, 2008
Not Rated (0)
sholt
Rating: 0%, 0 votes
It's likely a "hammer" is defective. This can be caused by
a build up of ink under the ribbon shield and/or around the hammer "fret" itself or the fret is physically broken. Remember
that this is a "shuttle" printer and each fret covers anywhere from
one to three characters depending on model. Some cover fractions of characters as well. The problem will appear as either
data missing on the left or right margin or a blank column of missing data going down the page.
A technician is required to solve all of these problems as the
shuttle assembly must be removed.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these Printers problems?
Printers
lexmark 2500 series
Printers
My c6300 printer will not print from the photo tray
Printers
Printout is just Like A green blue Scottish Tartan
Printers
respected sir, sir i want to download tone in virgin v...
Printers
z2300 is not printimg on or off line driver finshed...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
