Question about Nintendo DS Lite Console
Ds lite I changed the shell on ds lite and the top screen is on but no picture only withe, and the touch screen works but no respond to touch. I double tested the cables, The hinges ware broken pleas help....
  • Anonymous Jan 29, 2009
    The top of my screen is going black at random times during my game and it's driving me nuts!what should I do?!
  • 4 Answers
Sorry to say that your top screen needs completely replacing if it is doing as described!!
the bottom screen and the touch screen are seperate, jus mounted on top of each other, so if the picture works on the bottom then the bottom screen is fine just the touch screen is broken. again i think if the cables/ribbons are in correctly and it isn't responding then it will need replacing!!
Posted on Jan 29, 2009
I am replacing the shell on my ds lite and when after puting it back together the touch screen lights and works the the touch pad doesnt respond
It sounds like when you replaced the shell, you may have not reconnected the touch screen's membrane sensor. I'd open the system back up and make sure there aren't any loose or disconnected wires.
Mar 15, 2011 | Nintendo DS Lite Console
I am trying to change out the shell of my nintendo ds lite and cannot get the top screen to come loose from the bottom.
They have great manuals at www.powergamingparts.com that will show you expert pictures of how to take a DS apart. If you need more assistance please contact me.
Sep 29, 2009 | Nintendo DS Lite Console
Most of my ds lite touch screen is not responding
try getting to the calibration menu with the buttons and calibrate if u can if not send it in to nintendo for repairs
Sep 21, 2009 | Nintendo DS Lite Console
Bottom screen of Nintendo DS Lite won't work
Ok, I may be able to help you.
One is it new?
Two is it Damaged in any way
Three does it still have a warrenty?
four Can you post pictures (LCD may be dammaged)
May 10, 2009 | Nintendo DS Lite Console
Replaced the shell and now the touch screen isn't responding!
I have actually done this same thing attempting to repair my old gray DS. Had to replace the screen to screen cable and touch pad, but that is another matter.
When the DS screen to screen cables are out of place, the DS will act exactly like this. The screens will flash once and the DS won't even attempt a charge. This is a safety feature of sorts in the DS design to prevent a possible short.
I'm assuming you had to remove the screen to screen communication cable when replacing the shells so you most likely didn't put the cable in all the way into the correct ports.
Sometimes even if they are off just a bit the machien just won't use it and act like its outright dead.
Best thing to do is to go back and reinsert the cables again.
There should be a small line on the board just under where the cable should be. You need to try and aling the cable with this line as best as you can.
Push the cable as far back into the port as you can without forcing it in. You should never need to use much force at all.
Press the plastic tab down and lock the cable in place with the port and do the same with the second one.
Once thats done, plug it in and turn it on.
It should normally go into the settings as these are usually erased when the battery is removed.
If it continues the odd dead like behavior. Simply attempt the precedure over again until you ahve it right.
Commonly you may see odd colorisation and the like if the cable is in enough but not in just right.
Take your time with it and be paient. Its not always easy but isn't too hard once you figure it out on your own.
The same info should help with other cable problems like this aswell.
Good luck with the rerpairs.
May 09, 2009 | Nintendo DS Lite Console
Touch screen wont respond
double check that both cable/ribbons are connected properly to the motherboard, the small thin ribbon which curls over the top of the motherboard is the one which powers and reads the touch screen so double check this!!
if this is all in fine then im sorry to say your touch screen is broken and will need replacing!
Jan 29, 2009 | Nintendo DS Lite Console
Faulty game console
Maybe the ribbon cable was damaged. the ribbon cable is a flat wire thing used to connect the top screen and bottom screen. you can buy a ribbon cable on ebay for a cheap price.
if that wasn't the problem, maybe the bottom lcd screen is dead. you'll need to replace that.
Dec 26, 2008 | Nintendo DS Lite Console
Nintendo DS Lite problem
I THINK UR DS IS SCREWED UP BUT THE SHELL DIDNT DO ANYTHING
Jul 28, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Flickering screen
hey i think i got a solution, read the link i gave below credits to votahuan, its for adjusting screen flickers in both top and lower screen of ndsl, however i need you to do me a favor in return, hope you do not mind posting up the pics for me at renginez@yahoo.com once you found the two hidden screw at ndsl, im just having hard time finding it in fat nds, so i need a rough i dea of where it mite be located. Heere's the link anyways :-
LCD FLICKER SOLUTION
Jun 15, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
145 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
