Question about Dewalt 18 Volt Compact Drill Kit
Dewalt can i convert a US 2 pin to a european 3 pin on dewalt skillsaw
  • David Ford
    David Ford May 11, 2010
    By 2 and 3 pin I take it you mean the cord. The 2 pin is double insulated and the 3 is a grounded tool. The answer in that case would be no. There would be nothing to ground the DI to. It is designed and built with extra insulators for that purpose.
Hi there!
I am afraid you can't do that by the changing plug. However, you can do that by using a Step-down Transformer which will bring 220V to 110v that is what your machine is designed to run on. Check the wattage of your drill before getting a Xformer. Usually the stepdown x-former should have a proper socket at the output side. Good luck.
Posted on Jun 20, 2009
D51275 dewalt nailer quit working
O ring or stuck pin valve. Id check here for more info DEWALT com
Aug 15, 2015 | Dewalt Nailer. 1 in. - 2-1/2 in. 16 Gauge...
My Mach 1 electric scooter Is a 2 pin European plug so what fuse sicker would I need to get without them burning out 13 amp plug ok or .
It is usual practice to cut off the European plug and fit a British 13 amp plug even though adapters are available. The charger isn't likely to require much current so fitting a 3 amp fuse should be ok. If you discover the plug or the positive pin is becoming warm after some time you could increase the fuse rating to 5 amp, though I doubt it will be necessary.
Apr 19, 2015 | Car Audio & Video
Where does the green wire connect from the power cord on a dewalt dw 236 drill
The green wire is always the ground pin (ground connection)
Hope this helps.
Feb 28, 2015 | Dewalt Dw236 1/2" Heavy Duty Vsr Drill...
User manuel for dewalt dc390 battery powered skillsaw
Go to, put your model number in the 'Find Parts' box and hit search. There are two types of your saw, DC390B and DC390K, select the proper one and you can view or download the parts breakdown or instruction manual.
Dec 29, 2011 | Dewalt DC390K 18v Cordless Circular Saw...
Convert US 220V to European 220V
all you need to do is to purchase a power converter also known as transformer that converts the European 220v to110 v, so that American appliances will operate on European current.
Dec 01, 2011 | Miele W1926A Front Load Washer
12 gauge shotgun shell converted to metric (ex. 12 gauge + 20mm)
A ordinary 2 3/4 inch 12 guage shell equates to a European 70 mm. a 3 inch Magnum is a 76 mm.
Goof Luck.
Mar 20, 2009 | Omega Juicers OMEGA GUN LOCK 12 GAUGE...
Convert 2 pin dewalt charger to 3 pin how
By 3 pin do you mean the third pin being a ground. If so that charger does not have anything internal to ground to. It is a 120Volt Double insulated tool. Let me know if you are trying to do something different.
Jan 29, 2009 | Dewalt 18 Volt Compact Drill Kit
Trailer Connections
I took the vehicle to Bosch, an electrical expert in Germany.
Jun 28, 2008 | 1997 Ford F150 Regular Cab
Re: hannspree 37 inch
i have got a humax 32"lcd idtv.
my sky remote does not find it can i get a code to put in thank"s
Jun 07, 2008 | Televison & Video
Dewalt 18 Volt Compact Drill Kit Logo
134 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
