Question about Apple MacBook Pro PC Notebook
Macbook extra fan
I recently bought a new macbook 2 Ghz with aluminium body. Some mac users insist on installing a (cms) fan control but I am not sure whether my mac needs one. What shoul be the tolerable grade of heat of a macbook? Do I need to install a program for it?
Than you for your advice
  • Roberta Smith
    Roberta Smith May 11, 2010
    same advice i give for the bios.... if it works don't mess with it.
    Robert
    Scholar:
  • 108 Answers
The real issue seems to be that the system firmware designers haveoptimized for a quiet machine at the expense of the temperature. Theeasiest way to fix this? A firmware update,perhaps not unlike the one released recently with almost no details.Several reports from users indicated this update increased the use oftheir fans and fixed their heat issues. Isn't that an astonishingcoincedence?
Although Apple said that the update was to "System Management Control(SMC)" firmware, it was up to MacBook Pro (MBP) users to figure outthat SMC is the specialized controller that manages thermal and power conditions, and is in charge of running the portable's fans.
Within hours of the update, users began reporting that the updateseemed to increase the MacBook Pro's use of its fans, and usingdiagnostic tools, claimed that their machines were running up to eightdegrees cooler.
Click on blue link to update and fix fan issue.
Posted on Jan 29, 2009
Fan won't stop
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jul 27, 2012 | Apple MacBook Air Mac Notebook
I have recently bought the games Riven and Diablo 2. They are supposed to be PC and Mac compatible (I have a MacBook) but when I go to install them, get a message - "You cannot open (game) installer...
Install Bootcamp, install XP on it and the games in XP. BTW you will get much better framerates this way, OSX is worthless as a gaming platform (it's slower even than most Linux distributions).
Jun 28, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook black will not start beyond the initial 'bong'. Blue screen followed by endless spinning gear. PRAM, SMV reset, no go. Safe mode can't complete. With battery or on power adapter same result....
Hello yang2699tlk,
Try this instead of using your Leopard Disc.
  1. Immediately after the "bong" press and hold down "Command + S".
  2. Wait for blinking cursor and then type fsck -y (exactly like that).
  3. If you receive an "Appears to be OK" then type reboot and hit the return key.
  4. If you receive a "Disk has been modified" then repeat the fsck -y command until you get an "Appears to be OK" then type reboot and hit the return key.
This set of commands entered in "Single User Mode" will repair your disk. If this does not work remove the hard drive, plug it into another Mac and transfer your data to a different computer. Then install a new hard drive and reinstall Mac OS X.
Hope this helps, don't forget to vote. Thanks.
Feb 27, 2010 | Apple MacBook Pro Notebook
For years I've used Org. Quick & Easy 5.0 on my PC. Children just bought me MacBook and insist I change. HOw do I move my address book and calendar to my Mac. Still have my 5.0 CD disc. Thx Eagle @...
perhaps you can export you're adress book and calendar in a file from the PC. Then ask ical and adress book on the mac to import it. (you launch the program and go to files/import)
Jan 15, 2010 | Apple MacBook Mac Notebook
Help! I dropped a tv onto my macbook pro 2 ghz c2d three days ago and it worked fine until last night when a strange, matrix like green half image started flashing on the screen. I rebooted and now the...
Twist the Macbook body while turning it on. If that make the image come back, you have a broken logic board. There are Mac Repair Guides that show how to open a Macbook. Watch out for the ribbon cables, those tear easily. Replacement parts are usually available on Ebay. There are third party services that can do it for you, like Mac Repair NYC.
Dec 04, 2009 | Apple MacBook Pro Notebook
When typing an email in Mail on aluminium Macbook in Mail errors
Hi Sherry, When did this start happening and how old is the MacBook?
Go to software update (apple menu) and see if there is a firmware update available for your mac. I have a recollection of an update to fix an oversensitive scratchpad and/or keyboard issue (but I might be wrong).
Does it only happen with mail?
Jul 28, 2009 | Apple 13 MacBook Notebook Computer ...
My new 13 macbook fans are working properly.is it norm
There's a program called fan control. It will allow you to reset fan speeds. If fans are dead, they need replacement. If you want to do it yourself, the good news is, it'snot too hard to open a Macbook. Here is an Macbook Repair Guide that shows how to open an iPod. Just open it and let it try, clean off any corrosion you can find. If you want somebody else to do it for you go to iPad Repair NYC.
Jun 13, 2009 | Apple MacBook Mac Notebook
CD/DVD optical drive malfunctioning. Invariable performance with reading and ripping CDs. Cannot read DVDs.
upgrade your CD/DVD firmware from MAC website and install it.
if it does same even upgrading driver then most could be problem in optical lens so better taking back in the same place where you bought it from if its still under warranty.
or if its out of warranty then you need to take to Tech so they can fix it for you.
please post back if anything changes and rate all answers.
Apr 25, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Mac keeps shutting off by itself
Hello, this is called a "hard reboot" and can occur because of faulty RAM memory (have you added extra ram recently?).
It can also come form a dead hard drive, or a dead fan, causing overheat
Apr 06, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Microphone on Apple Macbbok 13" 2.4 GHZ,2GB
Check to see if the microphone works on the macintosh side of the computer, chances are it won't, microphone usage on Macintosh computers has been hit and miss, sometimes the microphone needs a pre-amp or USB interface like a Griffin iMic adapter.
Oct 23, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook Pro PC Notebook Logo
348 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
