How do I remove the agatior on a GE Top Load Washer? Older model...1WA85589 W, Ser: SB145 407
  • 15,935 Answers
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
Tip
How it works: Late model Ge top loading washer
The late model top loading GE washer is much different than it's original models that were so much more dependable than these newer ones are. To access the innards you must forst remove the front panel. Older models had the top pop up first but these newer models have the top bolted down. To get the top up you must first remove the front panel by using downward force on the top between the tiop and the front panel. It is not easy even for eperienced techs but cuss it a minute and it will come off. Once it is off you will notice the washer has an elecetric pump. Strings and junk get into this pump. It is easy to take apart and cleanup. The tub is suspended on 4 rods and the lateral movement is kept in check by 4 rubber cord mounted to the top called bungies. The motor and tranny can easily be accessed by removing the tub from the washer. After disconecting the power cable and pump the tub lifts out. Not all GE washers use the same motor or the same transmission method. Some do not even have a tranny. I have some GE washer service manuals.
GE front access late model washer
on Dec 13, 2010 | Washing Machines
I have a GE commerial coin-operated washer, model no: WCCB1030HOWC. My question is about "the speed of washing". When it's washing, the washing speed is very slow (slow than the general home-use...
Ive got a couple of the same model. They do agitate slower than previous models a couple of years older. I have gone as far as replacing the motor and got the same results. I can only assume that they are operating as Ge intended.
Oct 07, 2010 | GE WCCB1030 Top Load Washer
How to remove agitator from GE washer? Model WHDRR418G1WW.
how to remove agitator from GE hydrowave washer machine?
Feb 27, 2010 | GE WBSR3140DW Top Load Washer
Kenmore Extra Capacity Heavy Duty Washer, Model 4151090, Ser. No. Ca2301977, unable to find a parts list for this. Agitator won't spin, motor and pump works, it's older but can it be repaired?
I would try http://www.appliancepartspros.com/ I am sure that they can find the parts you need. They are the best place for parts and customer service. You will have to contact them because your model number doesn't come up in the search area, but I'm sure they can help. Ive gotten parts from them for a 35 year old GM Frigidaire washer.
Dec 30, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Where is the ge washer motor brake
On older models, it is part of the transmission assembly, but on newer models, it is an electrical brake within the motor.
Jul 18, 2009 | General Electric WJRR4170GWW Top Load...
Washer does not fill quickly for rinse cyle
check your water pressure if its good check the valve on the back of the washer to see if anything is stopping it up . you may have to replace the water valve
Mar 29, 2009 | GE WBSE2090A Top Load Washer
Water leaks under washer on floor - olderGE profile
I see Eric C was correct, that you did not post your correct model number. You did say older GE, and from your description it sounds like you need to replace the WH23X42 water pump (about $50). It is one 1/4 inch clamp on the bottom holding on the flexible drive, three 5/16 hex head screws mounting the pump body to machine, and four squeeze style spring clamps holding the hoses. (be ready to catch the water when you remove hoses)
Feb 17, 2009 | GE Profile WPRE6100G Top Load Washer
Removing cover assembly on GE top load washer
Is your washer a GE Profile Harmony? Do you want to know how to take the top off or the top of the agitor (pulsator)? The top of the washer has four screws in the back top behind the screen once you unscrew them the front of the washer has two clips one on each side and you have to kinda tap it with your palm to get them to pop.
Jan 03, 2009 | GE WPGT9360EPL Top Load Washer
Oil on floor under washer
Oil is generally not a good sign. It means that the tranny seal is blown OR it means that the tub seal is bad which allows water to enter the tranny (water is heavier than oil... if water gets into the tranny it will displace the oil and force the oil out)
This being a GE? I'd wager that a tranny job is in order. If the machine is less than 5 years old it's under warranty so you'd call GE at 1-800-GE CARES. If it's more than 5 years old? Your washer is no more than a boat anchor. Get a new washer, preferably a Whirlpool. The repair cost for a new tranny will out-weigh the value of the machine.
Hope this helps.
Mar 23, 2008 | Kenmore 22642 Top Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
