I have an Avent 5431 laptop and i figured out that if you press Fn+F2 it turns the speed of the fan down which then eventually causes it to overheat. How do i turn it back up to normal speed again?
  • 3 more comments
  • bumbalisquat Jan 29, 2009
    ive already tryed that.
    my fan is still working but is really low and pressing fn and f2 makes no difference.
    did you find something on there?
    i cant find anything, or is my true blonde coming out? ahaha
    thankyou so much for your help :]
    x
    sure thing
  • Roberta Smith
    Roberta Smith May 11, 2010
    hit fn and f2 again
    Brigadier General:
  • 5,158 Answers
  • Roberta Smith
    Roberta Smith Jan 29, 2009
    as that is a support forum for avent you might want to post that type of question there as i can't find the manual... look at the keys tho... do you see any that have a icon of a tiny fan... if so experiment with the function key. incidentally alot of those laptops get close to meltdown anyways.
    Robert
  • Roberta Smith
    consider bumping the rating to a fixya ?
    thanks
How do i turn off num lock?
Press FN+Shift+Num Lk key at the same time
Here are FN + F key combi for your reference.
Press Fn + F9 keys for Touchpad Lock (on/off).
Function Keys:
Fn+F1 Suspend switch
Fn+F2 WLAN switch
Fn+F2 Bluetooth switch
Fn+F3 Access to the E-mail
Fn+F4 Access to the Internet
Fn+F5 Brightness down
Fn+F6 Brightness up
Fn+F7 LCD on/off
Fn+F8 LCD/CRT switch display
Fn+F9 TouchPad Lock
Fn+F10 Volume on/mute
Fn+F11 Volume down
Fn+F12 Volume up
Fn+Space Power 4Gear eXtreme
Fn+C Splendid
Fn+T Power4Phone
Fn+V Camera capture
Fn+A Light Sensor
May 18, 2014 | ASUS VivoBook S400CA
Tip
How to use F1, F2 ?..Function buttons on Hp laptop.
For those who do not know how to use the F1, F2, F3..... buttons on HP laptops, here is an opportunity for you to know.
We see these buttons on most laptops but don't know what they are used for. F1, F2....... buttons are the first set of buttons on the keyboard. These buttons makes it easy for anyone to access some programs on the computer without using mouse.
Follow the below procedures on how to use some of these functions:
To put your HP laptop on sleep mode, Press and hold Fn button on your keyboard, (without leaving it) then press F5 (Fn + F4).
To lock your HP laptop, Press and hold, Fn button, then press F6 (Fn + F6).
To reduce the brightness of your HP laptop, press and hold Fn button, then press F7 (Fn + F7).
To increase the brightness of your HP laptop, Press and hold Fn button, then press F8 (Fn + F8).
To put your laptop on mute, Press and hold Fn button, then press F9 (Fn + F8).
To reduce the volume of your HP laptop, Press and hold Fn button, then press F11 (Fn + F11).
To increase the volume of your HP laptop, Press and hold Fn button, then press F12 (Fn + F12).
To shut down your laptop or to view other shut down options, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
To close any page on your HP laptop, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
Good luck.
on Nov 06, 2010 | Computers & Internet
Tip
How to use F1, F2 ?..Function buttons on Acer laptop.
For those who do not know how to use the F1, F2, F3..... buttons on Acer laptops, here is an opportunity for you to know.
>To put your Acer laptop on stand-by or to view shut down options, Press and hold Fn button on your keyboard, (without leaving it) then press F4 (Fn + F4).
>To make your Acer laptop be on sleep mode, Press and hold, Fn button, then press F6 (Fn + F6).
>To lock your Acer laptop's Touchpad, press and hold Fn button, then press F7 (Fn + F7).
>To put your Acer laptop on mute Press and hold Fn button, then press F8 (Fn + F8).
>To close any page on your Acer laptop, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
Good luck.
on Oct 23, 2010 | Computers & Internet
What would cause my aspire 5630 to shut down sporadically?
Shut down sporadically, caused by rising temperatures on the processor (processor overheat). Processor overheat, caused by damage to the processor fan. Processor fan function to reduce the processor temperature.
Possibilities and solutions
1. The possibility of sluggish processor fan. Processor fan spins, with a low speed, so it can not reduce the processor temperature.
Solution: clean the processor fan with a vacuum cleaner, or replace the processor fan.
2. The possibility of fan processor die.
Solution: replace the processor fan.
The characteristics of damage to the processor fan
After the laptop is turned off (more than 1 hour), the laptop can turn on and survive + - 30 minutes. In the period of + - 30 minutes, the laptop died suddenly, because the processor temperature exceeds safe limits (shut down temperature).
How to check
Laptop is turned off (more than 1 hour), then turn on. Download and install software to check the processor temperature. Ex. Real Temp 3.60. See the change in temperature. If the temperature continues to rise, it can certainly cause damage to the processor fan.
- Normal temperature, when first turned on + - 38oC
- Normal temperature, after turn on for hours 40oC - 45oC
- Temperature overheat processor, when first turned on 60oC - 65oC
Nov 18, 2011 | Acer Computers & Internet
How do you turn on wifi for dell latitude d610
There is not wireless switch on this model. To turn on your wireless you will need to hold down FN + F2. If this does not turn on your wireless its most probably disabled in the Bios. To enable it, press the F2 key at the Dell Logo on startup, move down to wireless, press enter and move to wireless control, make sure its set to Fn+F2/App, then move down to wireless devices and make sure it set to on. Press Esc, and save changes and exit.
Sep 08, 2011 | Dell Latitude D610 Notebook
Wireless capability Switch is off on dell vostro 1400.Is there another way to turn on switch.
There are three ways to toggle the wireless switch on/off, 1st, Fn + wireless button (F2 or F5), 2nd, the wireless switch on the side of the laptop, 3rd, it can be enabled or disabled under BIOS setup (Tap F2 when turned on the laptop).
Jun 30, 2011 | Computers & Internet
Ho do i turn my wireless on and off on a avent notebook i no its two of the top keys but which ones
wifi switch for your machine
7086/7096 - Button next to the power button
7100 /7104 - Fn+F2
7201 - Wireless key top Right and then Fn+F2
8117 - Small slide switch on the Front of Laptop
Oct 04, 2010 | Computers & Internet
Can figure out how to turn on my blue tooth functions on my dell m6400
If you have the Bluetooth option installed on your laptop press Fn+F2 and that should enable bluetooth.
Aug 31, 2009 | Dell Mobile Precision M6400 Notebook
Fn+f2
fn+f2 means your pressing two keys at once
the function key (fn - usually a different color - maybe blue - than the letter keys) and the f2 key
hold down the fn first then the f2 - look for the fn on the lower right or left next to Ctrl keys
Mar 30, 2009 | Dell Inspiron 6400 Notebook
How do you turn on wi fi facility on the advent 5431?
It is usually achieved either by a setting in CMOS, press del or F1or F2 to enter CMOS and looking for the wireless lan entry in the cmos files, if it is off, turn it on and save and exit.Other methods to,turn it on/off are by a combination of key strokes on your keyboard whilst in windows. This could be FN + F1 or FN + F10 for example. If you still have problems type in "turn on wirless lan" at the help text at the top of your screen, it should tell you there.
compdoctor2005@btinternet.com
Dec 27, 2008 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
