My phone is going haywire. It turns on, but the only button that works is the red hang-up button. Every other button makes it connect to the browser, and then none of the buttons work. I hit the hang-up button and it asks me if I want to exit the browser, but the yes and no buttons don't do anything. All I can do is hit the hang-up button again. I can't answer calls, change the volume...nothing works except the hang-up. Any ideas?
I have had this problem on my V3 also, turns out that the flex cable tends to get cold solder joints, find someone at one of your local mom and pop cell phone stores. Can usually find parts on ebay. Am not sure exactly which cable it is, had local tech that discovered he could solder the connections on the cable. http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=v3+flex+cable&category0=
The SGH-T739 (Katalyst) handset features a WAP (Wireless Application Protocol) browser that allows you to access and navigate the wireless web using your phone.
To connect to the internet just press the right soft key for t-zones, while in standby mode. The t-zones browser will be launched and the T-Mobile Web page is displayed.
To disconnect from the internet simply press the red end call button .
Turn off the computer, then hit the power button to
turn it
back on and immediately start hitting the F8 key repeatedly until you
see SAFE
MODE. Take the Safe Mode option and let it boot up. Safe Mode will look
different to you, the screen will be darker and the icons bigger, this
is
normal. If it works in safe mode, then turn the computer off and reboot
again as if you are going into safe mode, but this time take the Safe
Mode With Networking option (this will give you internet connectivity).
When it boots up open your internet browser then download and install
MalwareBytes, then run a Quick Scan.
Go to www.google.com and in the search box type:
"Download cnet Malwarebytes" (without the quotes). Download and
install malwarebytes from the sites download.cnet/malwarebytes. When the
site opens up click on the Green Download button on the left. Do not
click the Red Download button, that's junk. When it finishes installing the Gui
Interface will open up with an offer to Accept a Trial Version or
Decline. CLICK DECLINE you want the totally free version. Run a
QUICK SCAN. As it scans, if it finds infections the number will be in
red. When it finishes scanning, click SHOW RESULTS. A notepad text
document will open up showing you the results. You can close the text
document and go back to the Gui Interface where you will click REMOVE SELECTED
RESULTS. The objects will already be selected for you. When it
finishes removing the objects click ok and it will sometimes reboot your
machine.
If the problem still exists then purchase another keyboard on ebay based on the brand and model of your computer at:
http://www.ebay.com
