Question about Dewalt 18 Volt Compact Drill Kit
Convert 2 pin dewalt charger to 3 pin how
I got a dewalt cordless saw from the us is it easy to change plug to 3 pin
  • 2,176 Answers
By 3 pin do you mean the third pin being a ground. If so that charger does not have anything internal to ground to. It is a 120Volt Double insulated tool. Let me know if you are trying to do something different.
Posted on Jan 29, 2009
Convert Dewalt Charger DE 9116
It is not feasible to convert it internally.
Jul 15, 2013 | Dewalt 7.2-18.0 Volt One Hour Charger
Broken dewalt battery 18v lithium ion 2.0ah flashes fast red when in charger
When a Dewalt charger is showing a fast blinking red light it means the battery is no longer chargeable. It may be because of a bad cell or short inside the battery. Whatever the reason the charger will not charge the battery and it needs to be replaced.
Oct 07, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I NEED A CHARGER FOR MY DELTA CHARGER # CL 180C WHERE CAN I GET ONE AND DO THEY STILL MAKE THEM
good luck I rigged a black and decker from walmart so far it works it has 2 outputs and the 2 pegs on the edge of the batteries take the juice. It saves about 100 bucks cause you can pick up a b&d charger for 25 bucks.
Aug 11, 2011 | Dewalt DC727KA 3/8" 12v Cordless...
DeWalt charger #DW9107 binks eraticly, even when battery is not installed, DC output is 35 volts, which is too high, the reading across all of the diodes on the circut bd in the converter circut is 5.8...
There could be a number of things wrong inside the charger, and could cause more problems trying to replace components on the board. Your best bet is to look on ebay or some other place to see if you can get a replacement charger.
Mar 29, 2011 | Dewalt DW056 18 Volt Cordless Impact...
I have an 18 volt 1/2" drive cordless impact wrench made by DeWalt and when I pull the trigger the motor runs but not the anvil?
Sounds like you have a gear broke that runs from the motor to the shaft. Take it apart and check it out. easy to put back together. atleast you will know for sure and may fix it while it's opened up.
Jan 18, 2010 | Dewalt DW056 18 Volt Cordless Impact...
Tools are junk moved on to ridgid
Wait until you have problems with that Ridgid. Parts very hard to find. Ridgid Tools have great threading equipment like the 700 and 300, but their cordless tools are not easy to get help with. DeWalt has a very good warranty program. The dc920's have had a lot of clutch problems and switch recalls, though. Their saws (mitre, circular, etc.) Best in the business. Good luck, friend. Lemme know if you need anything. Please rate me.
Jun 12, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt
Hi there!
I am afraid you can't do that by the changing plug. However, you can do that by using a Step-down Transformer which will bring 220V to 110v that is what your machine is designed to run on. Check the wattage of your drill before getting a Xformer. Usually the stepdown x-former should have a proper socket at the output side. Good luck.
Gamba
Jan 29, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Sep 29, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Drill Motor Reliablity
some models have external brushes for easy changing - when the brushes wear down you can easily change them for new ones, some models have this feature ,it is only of use if you are using your cordless drill on a daily basis.
Aug 27, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt 18 Volt Compact Drill Kit Logo
154 people viewed this question
Top Dewalt Drills Experts
Soulvisitor
Soulvisitor
raysaw
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
