Question about Canon PowerShot S30 Digital Camera
Lens cover problem leads to LCD problem
The other day I was opening my Canon S30 lens cover and it sort of slid into a slightly ackward position resulting in the lens not coming out so photos could be taken. It was definitely off track, making a rasping sound and leaving a scratch on the front when I sled it open and closed. I played with it some and got it enough on track the lens pops out but now the LCS screen stays black though the viewfinder shows images. I don't know if it takes pictures or not at this point. My concern is finding out what happened and if it s fixable by someone like me who is mechanically inclined?
    Problem Solver:
  • 17 Answers
If the pics show up on the memory card, it's just an LCD issue.
Posted on Dec 09, 2007
Lens error, restart camera....the lens cover is stuck slightly open. I have tried all suggested methods. Is there anthing else?
hi
if you see lens error on back of lcd and lens barrel is stuck, then your camera would need replacement of zoom control gears or a whole lens unit. Either way your local repair shop would charge you almost same cost depend on time consume. the cost would be around $75 to 135 depend on what they realy want to charge.
Thanks and best regard!
May 23, 2011 | Canon PowerShot SX100 IS Digital Camera
Canon ixus 50 the camera is not switching on and the lens is open
Check the battery cover closes properly, the camera will not operate at all if the switch thinks the cover is even slightly open. Try removing the card, sometimes they cause cameras to not start when they are faulty. If all else fails, the fuse is most likely blown. They are internally located just near the power switch but you are best to have a service centre replace it for you. Best of luck.
Apr 15, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Dec 05, 2008 | Canon PowerShot A550 Digital Camera
Canon Powershot S50 -lens extends and then retracts
There is a common problem with the A series Powershots, that the lens assembly jams in the telescoping zoom, or in the digital imaging module, in which the lens assembly has to be replaced. I'm not sure if the S series has these issues. You can check with Canon support to find out.
Aug 08, 2008 | Canon PowerShot S50 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
LCD Dispaly malfunction
The screen has two components. The LCD, and the backlight. You can buy broken cameras relatively cheaply on ebay (or if you have it, craigslist). Do that, and you might be able to replace the screen.
Dec 03, 2007 | Canon PowerShot S30 Digital Camera
Need to know where the ribbons plug into the canon sd600 lcd screen
What ribbon cables are you trying to install? Would this be the LCD+Backlight cables? Or the Lens+CCD cables?
As for the lens cover, http://stores.ebay.com/DarnToothySam has lens flap/cover repair, email him if you don't see your camera there.
Nov 09, 2007 | Canon PowerShot SD600 Digital Camera
Open cover
The cover opens in two positions. To completely open the lens cover for shooting images, slide the lens cover over until you hear two clicks. When the camera is on the first position, you can playback images.
Aug 31, 2005 | Olympus Camedia D-510 Zoom Digital Camera
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
Canon PowerShot S30 Digital Camera Logo
70 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
