Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Picture went funny on my PT-47WX53 last night... a blue ghost like arc appeared mirroring the lower portion of the images displayed on the tv a few inches above where they were positioned. Most of the middle of the tv is fine, upon closer inspection it seems like the top is also doing it, though less pronounced than the lower portion of the screen. I've tried to adjust via convergence w/o success. It seems to have split blue and yellow into two seperate images, placing the yellow in the correct spot and the blue above/behind. Does that description make sense? The tv isn't new, fairly recently it was serviced by Circut City when it broke down under a warranty plan, but they did a poor job and I didn't renew the warranty. If I do need to call in a repair person could you speculate at what the cost may be? Is it worth it on an older tv? I'm on a very strict budget right now so any suggestions relative to cost savings would be greatly appreciated. Thank you! Kind Regards, Jeremy
  • 10,594 Answers
You need to replace convergence ICs in TV for correct converge picture.
Below is an image of D board and ICs are marked need to replaced.
If you are familiar with TV repair and knows basic electronics then can do this job OR call TV tech to fix it.
Posted on Jan 29, 2009
Ghost image arcs over picture
This tv have a convergence problems,it dead.The covergence board the 2 STK convergence ICS and some or all it resistors are dead.All these parts must be replaced to solved covergence problems.The shop will cost U $300-350 for parts and labors.
May 26, 2010 | Philips Magnavox 51MP392H Rear Projection...
I have a PT-47WX53 rear projection TV that has a 3-4 inch vertical bar that is in a purplish hue. Barely visible. Asking for suggestions of repair. Thanks.
There is one very common problem for this--the band of noise appears after the set is on for a few minutes but you have no picture?
Panasonic ECWF2474JSR C509 CAPACITOR .47UF 200V
SD TECH
Dec 28, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Green arc across bottom of tv,and a little purple.
Replace Both of your convergence ICs STKs, big black ICs.
Jun 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Blue Ghosting Images
You need new convergence ICs STK392-110 you need to replace both of them. Heres where you can order replacements and they provide free step by step instructions along with free online instant messaging with a tech so you can do the repair yourself. takes about an hour from start to finish. Heres the link.
http://servicemanuals.vstore.ca/
Apr 09, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Toshiba 50H82 blue arcing?
color shadows on numbers or letters indicate a possible convergence problem.. might be a crt deflection problem.
Dec 18, 2007 | Toshiba 50H82 50" Rear Projection...
Convergence Problem
The convergence IC's have been known to cause similar problems and both would be replaced at the same time. Not an easy job for a DIYer. I would get a repair shop to fix it.
Dec 19, 2006 | Panasonic PT-47WX5347 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
787 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
