Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
PHILLPIS 60PP9202 MAKES SQUEALING NOISE WHEN TURNED ON.
NO PICTURE, NO SOUND. SOUNDS LIKE A NEEDLE AT THE END OF A RECORD OVER AND OVER AGAIN. POWER BUTTON LIGHTS UP RED, BUT THAT'S IT.
  • Beck
    Beck May 11, 2010
    I unplugged cable 1516 and the tv screen lights up for about 5 seconds. Is the tv-kit-011 what I need to fix this issue?
  • Philips Master
  • 3,459 Answers
Sounds like one of two problems
1) Convergence chips are shorted....One quick test is to desolder and remove both STK392 chips....then power the set on. If the tubes light up the chips were shorted. You can get new ones from www.TvRepairKits.com
2) Another possible problem is a bad HVG - AKA the flyback.
Try the convergence chip test first. Note: On some Philips sets you can just unplug cable "1516" instead of removing the chips.
Posted on Feb 04, 2009
  • Edward
    Edward Feb 13, 2009
    Yes - for your set TV-KIT-011 is the correct kit.
I have a DC41. The power head wont turn and is making a squealing noise.
Sounds like your power head is seized or almost seized. Possibly real dirty. take apart and lubricate ends and replace the belt I feel is slipping Hence the squealing.. Clean all parts thoroughly.
Dec 02, 2016 | Dyson DC41
I have a Magnavox Digital Video Disc Recorder & Video Cassette Recorder. Model# ZV427MG9 A. When recording from a VHS home movie tape to DVD there is a high pitch squealing sound. When playing the DVD...
U play another movie like a Hollywood movie DVD disc play on it have no squealing noises wright?Yes,than the blank DVD discs batch u have is bad.Tries buy another batch DVD blank discs,tries recording again should solved this problems.
Mar 16, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Squeal when water first sprays at beginning of cycle
Turn off your water supply valves and remove the water lines one at a time. Shine a flash lite in the water valve and see if the small screens are plugged with debris. These can be removed with needle nose pliers and cleaned. Replace and try it again. If the noise continues you need a new valve.
Jan 01, 2010 | LG Washing Machines
Squeal which sounds like it's underneath the car.
Do you know if he turned the rotors when brakes were done?
Dec 01, 2008 | 2000 Toyota Avalon
Won't power on
my d52w19 chassis itc222 as posted most of the time wont turn on and the green light flashes three times every time it makes a small noise. sometimes it does turn on and you hear a little pop and the tv fires up.  latley there is a really high pitch noise that will slightly change pitch if you move the tv or put slight pressure on the top or botttom rear part of the chassis. thanks for the help as I have seen that this has been posted before without mention of the high pitch noise.
Aug 23, 2008 | RCA D52W19 52" Rear Projection Television
Flyback making a poping noise
You can get the replacement Flyback at the following link, and they provide free instant messageing tech support to take you step by step with the replacemnet proceedure. You need phillips 32942 flyback, its listed in their flyback catagory.
http://servicemanuals.vstore.ca/
Jul 27, 2008 | Philips 60PP9202 60" Rear Projection...
Stopped working and squealing sound
Your set is shorted circuit condition. The power supply is making the noise. Unfortunately almost any of the hi current circuits will do this. If picture went out 1st look for video or hi voltage problems.
Jan 11, 2008 | RCA 32F531T 32" TV
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Jan 01, 2008 | Samsung TX-P2670WH 26" TV
HL-r6167w wont start up (HELP)
it sound like the color wheel is bad
Nov 26, 2007 | Samsung HL-R6167W 61" HDTV
No sound no picture
Does any lights come on led on front of set? Does set make any squealing sound when you press power? If not then open and look at power supply board. This is the board that the cord is attached too. look for open fuse, check 2004, 1000, 1300, 1900, etc. See if fuse blown then look for short in pwr. supply.
Aug 29, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
179 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
