Question about Kitchen Ranges
How do I reset the clock on my AEG stove - Kitchen Ranges
  • 370 Answers
Try unplugging or shutting off the breaker for 10 minutes. This should reset the clock.
Posted on Jan 29, 2009
My stove panel went blank.
You will need to replace the clock/timer on the unit. Here is that part to order.
Frigidaire 316557114 Clock timer AppliancePartsPros com
Mar 22, 2014 | Kitchen Ranges
Oven wont' work regardless of proper installation
Hi Have you set the clock The way to do this is in the manual if you dont have a manual you can get one here http://www.manualsmania.com/download.php?link=65af94c83ee1528c47d230faaa77ad4c9697 Regards Geoff Stove Recyclers
May 28, 2011 | AEG D2100-4 Electric Double Oven
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Whirlpool stove clock malfunction..
you have a bad electronic oven control or in other words bad clock
Dec 30, 2008 | Kitchen Ranges
Stove with LED clock display, need to be set
Try holding 2 buttons at a time and whilst doing so, press the button with time on it or clock face, or just keep trying different buttons until myou get the right combination, stick with it you will get it to go.
Dec 15, 2008 | Stoves Ovens
Cannot reset clock on my electric stove after a power failure!
Unplug the stove for 10 minutes, then plug it back in.
This should resolve your problem...
Nov 20, 2008 | General Electric Stove/Oven/Range Chrome...
AEG Oven
try setting the clock, it may be automatic
Mar 22, 2008 | AEG B2100-4 Electric Single Oven
AEG B2100 Not heating up - light does not turn on
Main selector switch may have burned contacts.
Nov 07, 2007 | AEG B2100-4 Electric Single Oven
Kitchen Ranges Logo
89 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
