Question about Dwin TransVision 3 Plus Multimedia Projector
Video then Black
I have a Dwin Transvision 3. While viewing video from any video source (cable or DVD) the projector light goes out, however, the projector keeps running. The only way to get video back is to turn off the projector, let it cycle down completely, then turn the projector back on. First it flashes green or blue, then goes out. This may happen 5 times in 10 minutes, or only once in an hour. DWIN has requested I send it back (no longer under warrantly) and they want big bucks just to look at it...any suggestions... Thank You -
  • 2,239 Answers
The colorwheel is going bad and needs replacing.
Posted on Aug 19, 2009
SOURCE:
I have a transvision 3 that starts up and runs fine. at some undetermined point the picture will flash back and forth from snow to the clear picture????
prestopete here...no kidding..I have the same problem...Can't find any cables. I do have a source for bulbs if you need.
Mar 25, 2012 | Dwin TransVision 3 Plus Multimedia...
Plays for couple minutes or hours, then goes
Have you considered checking the lamp? It could be going bad.
Nov 15, 2009 | Dwin TransVision 3 Plus Multimedia...
No video is coming out of my Trans3 projector what can it be?
Not sure. I am looking for parts for mine. Please help if you can. Will buy dead projector. [email protected]
Oct 05, 2009 | Dwin TransVision 3 Plus Multimedia...
Replacment of bulb on dwin transvision 3 plus ceiling mounted
It is fairly simple. Take the unit down as you need to get to the underside. There you will see the retaining screws that hold the cover on. Remove these and open the unit. Inside you will see the bulb and mounting bracket. Off hand I don't remember exactly how it is held in place but there are a number of screws and a lead to disconnect to remove it.
Mar 09, 2009 | Dwin TransVision 3 Plus Multimedia...
Dwin Trans 3 Shadowing at Edge
you'd need to remove the top from the projector. the light tunnel is between the colorwheel and the lens assembly. remove the metal frame from it. chances are it's falling apart. since the company's out of business, finding a part is an exercise in futility. time to trade up.
Jan 07, 2009 | Dwin TransVision 3 Plus Multimedia...
I HAVE DWIN TRANS3 PROJECTOR 3 YEARS OLD PROJECTOR STOPS WORKING IN 5 MINS, FIRST PICTURE GETS FUZZY AND NO PICTURE BUT SOUND STAYS ON, I ALREADY PUT NEW BULB BUT SAME THING
it's time to clean it out. the colorwheel might be going and if it doesn't spin to keep in sync with the dmd chip, the lamp goes out.
Nov 21, 2008 | Dwin TransVision 3 Plus Multimedia...
Bulb or power problem?
You have to order it on the website and they are terrible about getting back to you. Worste customer service in the world. Terrible
Jan 03, 2008 | Dwin TransVision 3 Plus Multimedia...
Dwin lamp turns off
I design and implement switching power supplies for the commercial lighting industry. I also own a DWiN Transvision and have opened it and worked on it several times. I believe I can answer this question.
The DWIN projectors use a proprietary switching power supply to strike the lamp and keep it burning. The power supply is extremely sophisticated and maintains tight voltage and current tolerances. This is important because the halides in the lamp are damaged by power supply fluctuations. The halides can often be seen in an unfired lamp, they appear as small specks of dirt or tiny beads inside the lamp envelope. When a metal halide lamp is struck, the halides (which are rare earth elements) vaporize and cling to the inner wall of the lamp envelope. The mixture of halide gas in the lamp is what determines the color temperature of the lamp, as well as the accuracy of the lamp across the entire color spectrum.
One of the ways that DWIN is able to deliver such great color is because they use a lamp which delivers this great color across the spectrum, but, as I pointed out earlier, can be damaged by fluctuations.
The power supply contains three switching sections and five references for such things as input and output voltage for each psu section, as well as overcurrent demands from the lamp.
From my experience, your lamp(s) are all exhibiting issues that require replacement.
Sep 25, 2007 | Dwin TransVision 3 Plus Multimedia...
Dwin TransVision 3 Plus Multimedia Projector Logo
316 people viewed this question
Top Dwin Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Marvin
Marvin
Are you a Dwin Office Equipment and Supply Expert? Answer questions, earn points and help others
