Question about RCA F36444 36" TV
RCA F36444 Hello My RCA F36444 is giving some trouble. The power light keeps going on and off while making a funny noise. Someone told me it's the flyback. Can this be fixed and where can I get the parts? Thanks
I have had the same problem, then the tv died. I sent it in for repair and was told it was the transformer. Once fixed I've had no problems since. Hope this helps. Also total cost for repairs was 155.00 parts and labor.
Posted on Aug 01, 2009
SOURCE:
RCA HD52W59 Power button lights three times when pushed and unit makes squealing noise each of the three times the light comes on then nothing. No power, no light, etc...
replace the flyback which is the 270125 flyback. You can get the 270125 Flyback repair kit at the following link which contains the flyback plus detailed instructions on CD
http://www.tvrepairworld.com/
Jul 17, 2009 | RCA HD52W59 HDTV Projection Television
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
Power wont come back on TV
the most common component to fail with that sympton is the flyback. If the chassis is a ITC222A the flyback will be 259296 or 265409 as they were both used in that chassis and model number. If you need more assistance let me know the Chassis number from the tag in the back.
Mar 13, 2009 | RCA R52WM24 52" HDTV Projection Television
My tv will not turn on any more.
OK,These sets are well known for Bad Flyback transfomer and shorted hori output transistor,noise your hear is caused when hori output is shorted .FBT# 239111 Acme has them with 1yr. warranty have phone number at shop will get back to you with that asap.replace these 2 parts and that will fix TV
Dec 11, 2008 | RCA Televison & Video
Rca 52'' tv
check for vented caps or shorted flyback or tripler.
Aug 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV
You could very well have a defective flyback, as thats the item most prone for failure with that model. You can get a replacment flyback at the following link and they will sign you up for free online instant messaging while you do the replacement so they can take you through the entire process step by step. You need flyback 259296. Heres the link.
http://servicemanuals.vstore.ca/
Aug 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca big screen television 65 inches
the clicking is the relay clicking which is one of the first components when power is applied. Your set will need to be diagnosed by checking the stanby and start up circuitry. Unless you are skilled this is one chassis thats left to a skilled repair tech. They have alot of problems with the power supply and deflection circuits, flybacks and etc.
Apr 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca p60752eb
Disconnect the lead from the flyback to the splitter. Place the flyback lead securely in a dry glass container and try to power up the set. If it doesnt shutdown the HV Block (splitter) is bad.
Feb 11, 2008 | RCA P61960 61" Rear Projection Television
56" RCA projection TV (FLYBACK related problem)
the base to emitter of the hot will read short on a diode checker/test on ohms it vairies but typically about 50 ohms.e to c, or b to c should have very high resistance. unsolder the collector of the hot. make sure all solder is gone. now test the ohm between your tuner ground & the pad of the hot collector it should read open.
Jan 16, 2007 | RCA P52921 52" Rear Projection Television
Blank screen, power light clicks on and
This sounds like the common problem for this set. A bad connection in the sweep section or a bad flyback and a bad horizontal output transistor. Good Luck.
Aug 08, 2006 | RCA F36444 36" TV
RCA F36444 36" TV Logo
102 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
