www.manualslib.com > Brands > Wolf Manuals > Cooktop > DD36I View and Download Wolf DD36I user manual online. ... cooktop. Wolf downdraft ventilation systems are recommended. for use with Wolf electric ... The downdraft will operate most efficiently when ductwork does not exceed 40' (12 m) in length.
Hello, Most projectors have a 1/8 inch (mono) or tip and sleeve female connector for screen trigger and output 12volts dc when the projector is powered up. So if the Optima screen has the optional trig in and it's 12 volts the cable is very easy to put together. Optima may have a cable available or you could spend just a few bucks at Radio Shack and your all set.
Change the bateries,clean the IR LED'S,both the remote,and the projector.Some kind's of functions was set for use before.it was not turn off or clear out of the memorys,that why u getting a not applicable message.
A bit unusual for the projector to stop responding to the remote.
Usually it follows when someone has opened the projector, they forgot
to reconnect the controls from the case top which also includes the IR
receiver. If it isn't that, it could be a broken IR pc board or
bad connection. I've seen that.
The worst case is that the IR controller on the main board has failed
and if that's the case, you'll have to live with it as the cost of a
new board is very high.
You do so by doing the following:
1).Start the projector.
2).Press keypad <Source> and <Auto> keys simultaneously, enter " Lamp Hour info" layer
3). Press <Source> and <Auto> keys simultaneously again, then enter factor menu.
Do not change anything till you reach Lamp Layer where lamp hour and usage hour is given. If you reset, then all data revert to default - factory reset. you may chage here or under (2).
Let me know if this solves your problem.
