Question about Canon PowerShot S30 Digital Camera
Granddaughter forced memory card into slot incorrectly and bent pins
My granddaughter forced the memory card into the slot incorrectly and bent a couple of the pins at the base on my Canon Powershot S30. Does anyone know of a way to get to the pins so they can be straightened? We've straightened crooked pins on mice using the hole in a ink pen and I would try that but first I have to be able to get to the bent pin.
    Problem Solver:
  • 17 Answers
A long pair of needlenose pliers, or possibly tweezers. As you've noticed, it's near impossible to disassemble the needles from the mem card housing.
Posted on Dec 09, 2007
HP short beep long beep
Sounds like you have issues with your memory cards. Did you add any memory recently?? If not, just make sure your memory cards are plugged in ok. If that does not sort out your issue, you may be forced to purchase new memory to rectify the problem.
Rgds.
Apr 16, 2014 | HEWLETT-PACKARD Pavilion p6514f PC Desktop
Bent pin memory card slot
The repair shop, probably will charge more then a new camera, even newer than yours will cost. In my young years I had to learn to adjust relay contacts, and that was not easy, if you want them to survive all. I won't say it is impossible, but it would be a nasty job.
If it is only one pin you have bent, you could try to use one or two little knives or other small and flat tools, and coming from a different side, you could try to come on the pin. If they are not bent that much, you could try to use an old and defect CF card,
Use a little saw, to saw from top to bottom so you are left with a pice with just a few rows of contact holes. you could try to place the piece of the old memory card on a few pins endif they fit, careful press the part of the card down. Or if the pins are bent a lot. shift the part over the pins and try to bent them straight.
I don't know how far the pins are bent, but just try something, without opening the camera.
Jan 09, 2014 | Canon Rebel XT / EOS 350D Digital Camera
My granddauther lock my phone.it says pukcodeis blocked contact your provider. so idid they think sims card defected.need new card
There is a PUK2-code, which is used when the PUK-code is entered incorrectly 3 times in a row. If the PUK2-code is entered 3 times in a row incorrectly the sim-card blocks forever, then the only solution is to get a new one at the carrier's office. Looks like your granddaughter did right that so the only solution is to get a new card.
Mar 24, 2011 | Cell Phones
THE CAMERA BRINGING A NOTICE ON A SCREEN ERROR CF.WHAT IS POSSIBLE THE PROBLEM.
Digital Camera: How to Fix Compact Flash Memory Cards ErrorIt is not very typical for compact flash memory cards to give you an error. If you do receive an error, it most likely means that a pin within your CF card slot is bent, or your CF card has become corrupted. Unfortunately, if your CF card has become corrupted, you will need to reformat the memory card, which means that you may lose any pictures that were located on the card.
Fixing Your Flash Memory Card
You will want to remove your CF card and the batteries. Take a look inside the CF card slot to see if there is a bent pin. If you find a bent pin, you can correct this problem using a very small and skinny flat screwdriver. Moving very slowly, use the screwdriver to bend the pin back into place. You do not want to use enough force to make the pin back in one shot.
The pin does not have to be perfectly straight, but get it as close to straight as possible. Insert your CF card back into the slow very slowly. You should see the in align itself with the card. You can turn your digital camera on to verify that the compact flash memory card is now working.
Mar 11, 2011 | Cameras
How do you download the camera memory ( HP CB350
In the camera menu, there should be an entry for "copy" which should give you the option to copy the internal memory to the memory card.
Apr 03, 2010 | HP CB350 Digital Camera
When I try to put my memory card into my Canon EOS 50D Camera memory slot, it won't go in all the way. And I have tried a million times.
The two most likely causes are the card direction (I assume you've tried flipping it over), and bent pins in the bottom of the card slot. Take a look deep into the slot and look for any bent pins. They're very delicate, and don't like to be bent back and forth. I have had good success by straightening them with a thin screwdirver.
May 08, 2009 | Cameras
PS2 just states that there is no memory card in slot
    This shows that the memory card section getting malfunctioning,This could be due to dust or misused or inserting the memory card forcely which cause damage in its pins,Therefor,You have to consult any expert nearby.
Thanks for using fixya.
Nov 24, 2008 | Sony PlayStation 2 (PS2) Console
Kodak C340 Memory card Formatting
The write protection is on the card (a little "pin").
Aug 15, 2008 | Kodak EasyShare C340 Digital Camera
Not working
Try a different memory card. Some of these cameras may not support large sizes. Try a smaller card such as a 512 or a 128.
Aug 08, 2008 | Canon PowerShot A80 Digital Camera
Problem
Look at the bottom of the memory card slot, you probably bent one or more of the contactor pins. Use a small screwdriver and carefully try to straight the bent pin then carefully put the memory card back in. From now on, use a USB cable for downloading your pictures and don't pull the card out anymore as the pin is probably weaker than before and can break. Good luck
Sep 04, 2007 | Cameras
Canon PowerShot S30 Digital Camera Logo
207 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
