Question about Dell 3000cn Color Laser Printer
Error Code 004-332
I have a Dell 3100cn with a error code 004-332. It says to restart printer. I tried to replace the drum eventhough it didn't request for one.
Dell 3100 cn
Error Code 004-332 problem Dell Printer 3000cn
Has Error Code 004-332
I am unable to take cartridge out and it says to restart the printer. I keep turning it off and on and the same message appears. How do I fix this?
    Brigadier General:
  • 5,158 Answers
Try unplugging it for about 10 minutes and starting it up again... that hopefully will reset it.... have you found out what that error code is
Robert
Posted on Jan 29, 2009
    New Friend:
The drum unit on this printer is problematic. What happens is that there are two little rollers inside the drum that are supposed to keep the big rubber belt centered, but they don't work well. The belt slips past one of the rollers which causes this little reflective silver square to not be visible to the printer, giving you the error.
If you pull the drum unit out of the printer and set it on your desk the same way that it came out of the printer with the arrows pointing away from you, you will see by looking at the roller on the top next to where the arrows are pointing right away if the belt is off to one side. The rubber should equally overhang the metal roller.
If you buy a new drum, it will fix the problem, but if you would rather save $170, here's what I do: Remove the top plastic cover that covers the drum unit. I don't think that you have to remove the two screws on the front of the unit (side opposite the arrows) where the unit makes a curve. These are the screws that hold the rollers that center the belt. Once you have the cover off, grab the very edges of the belt and keep rotating it and pulling it to one side until the belt is centered on the rollers again.
You will see the two little centering rollers that are the screws where the unit makes a curve. The problem is the little roller is not positioned well. This is a poor design of the drum unit. I loosen the screws and fold up a very small piece of paper and stick it in between the drum housing and the small roller base then tighten the screw back up. This will cause the small centering roller to aim more downward, which will prevent the rubber roller from slipping to one side again.
Last time I did this, the fix lasted for about a year and a half. It beats buying a new drum.
Posted on Nov 10, 2012
2 Suggested Answers
SOURCE: Error Code 004-332
Error code: 004-332
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer.
Posted on May 13, 2008
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
004321 restart printer error
Nov 30, 2010 | Dell 3100cn Laser Printer
Getting error code 004-321 on my dell 3100cn. How do I fix it? Wont let me spin the drum and don't know how to take it out.
the belt inside the drum has moved to one side and the printer can't read the magnetic patch on the belt. open the drum and move the belt over and replace it , then turn it on,... it will keep doing this, so you will need to replace the drum...
Oct 19, 2010 | Dell 3100cn Laser Printer
Getting 004-332 restart error
Hi
Error code: 004-332
1. This type of error code implies that you need to restart the printer again.
2. However, do check to see if toner cartridges are seated in the proper position.
3. Also ensure that they have been locked in.
Jul 14, 2010 | Dell 3010cn Laser Printer
We are getting error code 004-332 Restart Printer on our Dell 3100cn printer. We have tried unplugging and restarting print spooler but it still come up witht message when we try to print
Hi
This error code on Dell 3100CN occurs when toner cartridges are not seated properly and/or are not properly locked in. Turn off the printer and unplug it. Now, you need to open the front door and pull out the drum. Try moving the carousel and check if it moves freely. While moving the carousel back and forth try adjusting the cartridges. try to unlock the cartridges and lock them again.
Now turn off the printer and turn it on after 1-2 min.s.
Daniel Scott
Jun 24, 2010 | Dell 3100cn Laser Printer
My dell laser printer 1320c has printer error code 091-935 come up what does this mean?
this error means
Replace DrumCart
091-935
Drum Full of
Waste Toner
The drum cartridge needs to be replaced. fro more information about how to remove it you can got to following link
http://support.dell.com/support/edocs/systems/3100cn/en/UG/section22.html#172399
Sep 09, 2009 | Dell 1320c Laser Printer
Code 004-332
Error code: 004-332
Dec 06, 2008 | Dell 3000cn Laser Printer
Dell printer
Error code: 004-332
Aug 26, 2008 | Dell 3100cn Laser Printer
Error Code 004-332
I tried this solution but wasn't quite sure how it's possible.
"Pull out the drum. Open the front door. Then close back this door then at the same time, move
the carousel around back or forth. The carousel now is able to be free to rotate. During rotating
you try to pull out the catridge. If it is locked, then adjust it to the position to be free."
Instead i pulled out the drum unit and pushed down with a bit of force on the toner carousel. I heard the gears grind which didn't sound real pleasant but the error went away. Instead I received an error message this time to remove and reseat the Cyan toner. Tried this multiple times w/o luck so i replaced the Cyan toner and it freed it up. Now I'm getting a paper jam message but there is no jam. Stuck again but making progress...
Feb 21, 2008 | Dell 3100cn Laser Printer
Dell 3000cn Color Laser Printer Logo
1,425 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
