Question about HP PSC 1315 All-In-One InkJet Printer
Canon printer problems
Hello, when i try to print anything, the printer prints from the bottom first..so when it comes out of the printer you can see the bottom prints then goes up but it leaves a big gap on the bottom so the top portion of the page gets cut off..is there a way i can change this so it prints top first?
  • nyechaitea Feb 02, 2009
    When I try to print, the computer goes through all the questions and then says it is printing, but nothing happens.
  • 63 Answers
It is in the printer settings, try to do a print preview first....it will show you how it is going to be printed
from there you can change the settings to the format that you want
Posted on Feb 03, 2009
Anything printed from our canon printer is showing a "striped" background. Have changed ink cartridges and have cleaned the printer head but still have the same problem
The stripes are generally caused by a blocked nozzle (or 2).
Remove the cartridges and then remove the print head from the printer.
Run the print head under some warm water for a few minutes - concentrating on the pit at the bottom where the ink comes out - all those coloured slots!. When the water runs clear. take some kitchen roll and dab the thing dry - don't rub. Make sure there is no water on the electrical contacts on the back and refit the print head into the printer and then the ink carts.
Try a couple of prints now. What happens?
Mar 18, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Mp 510 printer does not print
mine is the same. did you find a solution to this problem?
Feb 15, 2010 | Canon PIXMA MP510 All-In-One InkJet...
My canon ip1900 printer does not print even though it sounds like it
Your printer cartridges have likely dried up. You can try removing the print cartridges from the printer and pressing the print head (the bottom where ink comes out) into a moistened paper towel. This will hopefully rehydrate the dried ink in the print nozzle. Ink will likely transfer onto and through the paper towel, so please take precautions to not soil anything.
If this does not work you will likely need new printer cartridges. Refills can be used with decent success for the black but the machine will likely refuse a refilled color. Unfortunately this is how Canon has designed the machine. An original should be used in this instance.
Jan 14, 2010 | Canon Office Equipment & Supplies
Changed the print head in my Canon MP760 but now printing is blurred and very faint
Try cleaning the felt pads where the print head would rest when not printing. They get full of ink and cause more printing problems. I use water to clean them.Don't loose them, they are needed to keep the print head from drying out.
May 31, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Canon mx310 feeds paper w/out printing
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer Problem
Hello Dear,
The nozzles of the print head are jammed. you can try this take about 50 ml of luke warm water (please ensure that the temperature of the water is not too high as it may spoil the print head physically) in a small flat base dish and keep the print head in it (only the bottom part the nozzles should be dipped and not the green circuit chip) for about 30-40 minutes there are about 40% chances of print head recovery, if this solves your problem them its ok or you have to purchase a new Print Head for your printer.
Warm Regards,
Manoj Joseph
+91 9352008418
Mar 25, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Only prints black & blue
I have a similar problem - i can print all colours apart from red.
I've tried cleaning, deep-cleaning, and even bottom plate cleaning but of none if this improves anything.
Tried cleaning the print heads and nozzles with cotton buds, but this dont do anything. Even tried re-seating the cartridges but this does nothing either
Mar 21, 2008 | Canon PIXMA iP2000 InkJet Printer
Bad quality printing from the black cartridge
Select the correct Media Type setting (Windows)Print an image from another source
Change the Print Quality Settings (Windows)
try these if they dont work time for print head replacement.,
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10236
Nov 30, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Canon PIXMA iP4000 problem
you are probably missing the bidirectional support setting in the print server...some printers simply cannot be print served and this may in fact be one.
Sep 09, 2007 | U.S. Robotics USR7500A Print Server
Trouble with color printing
Have you tried to print a 'test page?'...
Go to 'Printers and Faxes'. Select right click on your printer and select 'properties' on the Printer properties window, select 'Print Test Page' (button at the bottom of the window.
Let me know what's the reseult.
Mar 11, 2007 | Canon MultiPASS C530 InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
