Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore fridge beeping
When the fridge is closed, sometimes theres a beeping sound and the display comes up as if I was adjusting the temperature. I'm not sure if its a jammed button.
  • zava Nov 26, 2007
    I have an Fisher and paykel refrigerator. We moved it from one house to another just a short distace between the two houses. After plugging it in the new house I find that it beeps sometimes once or twice a day. When I hear the beeping I open the fridge door and press one of the three buttons that are there and the beeping stops. Do you know what is the cause and what I should do about it?. Thanks
  • Anonymous Mar 16, 2014
    The alarm keeps beeping and the display is mostly out. Sometimes it comes on briefly and the light is flickering. It is still cold but not sure what temperature.
  • 183 Answers
More likely the light switch is not working or the door/drawer is not closed properly. Regards Advisor
Posted on Aug 23, 2007
SOURCE:
My F&P fridge was beeping whenever I opened it and temperature gauge at top back kept turning red. It seems to be ok now but what would be the problem?
the temp setting inside the fridge is too close to minimum temp for the sensor
if the door seals are not effective and you open the door it sounds
try turning the fridge setting to 4 or 3 to see if that fixes the fault at 1 it should take a few minutes to make a sound
call a technician if the adjustments do not work
Mar 25, 2017 | Refrigerators
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
My kenmore coldspot mode 106.53394300 is freezing items in the fridge
If further adjustments cannot be made to the thermostat, the next step would be to replace the thermostat or if so equipped, the temperature thermistor.
Jan 30, 2015 | Kenmore Refrigerators
What causes my Kenmore to buzz when dispenser door is closed?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Sep 14, 2014 | Kenmore Refrigerators
Ice maker does not dump regularly. Sometimes it dumps sometimes it does'nt.
Hey this problem sounds familar.I live in guyana and believe me it is a hot country.if you open the fridge door often then it would not build up sufficient coldness,in freezer compartment(because the air circulates in fridge.another issue,you need to ensure the ice tray in in all the way.you can also adjust the temperature settings higher is fridge and freezer compartment.this would solve your problem.
Sep 01, 2010 | Kenmore 50532 / 50534 Side by Side...
The alarm beep which tells you to close refrigerator or freezer door now beeps even after either door has been closed. It beeps three times at approx twenty second intervals, then beeps continuously for...
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
Aug 15, 2010 | Fisher and Paykel Active Smart® E522BR...
My 9 yr old Kenmore Elite fridge is warming up!! The freezer is fine!!!! Model 3 106*74902401 Seriel # ES423704 Manufacture date is 10/2005, I purchased it in Dec of '05 and it's been WONDERFUL!!
This problem sounds like a damper control broken or frozen.
Lowering the freezer temperature may help to fix the problem as the damper sometimes freezes and not able to open to cool down the fridge side.
If lowering the freezer temperature doesn't help, you may need to call for a technician to fix or replace the damper control.
Also, be sure the door closes properly and no air comes in or out from the fridge.
Dec 18, 2009 | Computers & Internet
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
Freezing food in Frig especially lower compartments
Is you refrig. cycling off and on?... sounds like a themostate if its NOT.. you might see if you have vents that have adjustments.. pull out the crispers and check for adjustable vents ... if there close them down some.
Aug 30, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
1,267 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
