Cars & Trucks Logo
sean mcginnis Posted on Jan 26, 2013
I have a 1998 dodge ram 4x4 with a 5.9, engine has been idleing rough, it idles fine for about 30 seconds then runs rough, almost to stalling, also the gas mileage is like 3 miles to the gallon. i had it hooked up to a computer and the codes were PO171 a maf sensor (i know, no maf sensor and PO720 speed sensor, my question is, not having a maf sensor, what could be setting off that code causing my engine to run rough?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 30, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
526
Points
If the speed sensor code is coming up change it. the sensor went out on my truck and it would die when i was slowing down and hit the clutch to downshift
4 Related Answers
Robert Debison
  • 412 Answers
  • Posted on Jun 22, 2009
SOURCE: 1998 ram 1500 5.9 gas rough idle,hissing sound from air filter
SHOWING MISFIRES ON SCAN TOOL?IF NOT,ENGINE CONTROLLER HAS NOT LEARNED MISFIRE MONITOR..WILL HAVE TO BE DRIVEN A BIT FOR RELEARN..IF YOU CAN SEE MISFIRES..MISFIRING ON MORE THAN 1 OR ALL CYLINDERS?CHECK UNDERSIDE OF IGNITION COIL FOR CRACKS..IF NOT CRACKED,YOU MAY HAVE A FAULTY CRANK SENSOR..ANY CORRODED PLUG WIRES AT DISTRIBUTOR CAP?ALSO CHECK IF ANY OIL PRESENT IN INTAKE MANIFOLD..GASKET ON BOTTOM OF INTAKE MAY BE BROKEN CAUSING AN INTERNAL VACUUM LEAK
Anonymous
  • 7353 Answers
  • Posted on Sep 21, 2009
SOURCE: Dodge Intrepid codes
could be a vac leak. what are the definitions for the codes??
Anonymous
  • 15 Answers
  • Posted on Dec 04, 2009
SOURCE: 1998 dodge ram pickup 318 eng.
If the engine seems to run fine over 1450 RPM maybe there is a vacuum hose leaking or EGR valve is slightly stuck open. Any help from the OBD II trouble codes? Or is there simply no MIL and no stored information in the OBD II computer read at the local parts store through the connector by the drivers knee?
Anonymous
  • 112 Answers
  • Posted on Dec 05, 2009
SOURCE: rough loud engine sound when van idles
sounds like your lifters
2answers
1997 dodge ram 1500 4x4 abs light on runs fine idles good but put it into gear wont go past 35 mph engine running smooth even at 35 mph
Bernard's Blog: Dodge Transmission Output Speed Sensor
bernardsblog.blogspot.com/.../dodge-transmission-output-speed-sensor.h...
Sep 8, 2009 - My 99 Dodge 2500 Ram won't accelerate..transmission is NOT slipping,.... It has been running fine and the check engine light even cleared itself yesterday.... So it wouldn't go into first gear and then 3 minutes later my check engine ... I have a1997 Dodge Ram 1500 with a 5.9L instead of the stock 5.2L. It ...
Dodge Ram Idle and Stalling Problems - Car Forums at Edmunds.com
forums.edmunds.com > Dodge > Dodge Ram Pickup 1500
Aug 17, 2011 - 30 posts - ‎25 authors
Learn more about Dodge Ram Pickup 1500 at the Edmunds.com ... The crank sensorwas put on however it started stalling again. ... The truck starts fine, but will only runat 2000's RPM and only then if .... Then as I start driving about 1/3 of a mile go dead again, I knockout of gear, crank back up immediately.
WILL NOT GO OVER 30MPH WITH PEDLE TO METAL ...
repairpal.com > Questions > Dodge > Charger > 2006 Dodge Charger
I WAS DRIVING FINE AND THE CAR ACTED LIKE IT GOT STUCK IN ... Then the transmission didn't want to change into 2nd gear. .... Whenever i start up my car theabs and esp light turn on and when i try driving it doesnt go over 30 mph even .... in neutral but not it just wont go up hills and i think it has something to do with
Dodge ram 1500 5.9 idles rough and stales out
This truck has problems with the cover inside intake leaking vacuum and causing rough idle and oil usage , its hard to say what your problem is with out testing, have you had the check engine light scanned for codes? what year is this dodge?these also had intake leak problems. try starting the engine and let it idle and then with some carburator cleaner spray around intake gasket and see if idle changes if it does then you have a intake gasket leak, another problem may be a leaking injector, try some sea foam in the gas tank and run a half tank of gas and see if that helps, otherwise a fuel injection system cleaning would be the way to go but this is only if its an injector problem, if this truck is 1996 or newwer have the computer scanned at an auto parts store for any codes. if there are codes let me know what they are even list the code and #. good day
1998 1.4 PUMA RUNS FINE AND IDLES FINE REVS PROPERLY BUT THEN WONT IDLE ?
ngine stalling and rough run issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
2answers
Transmision shudders when up to speed ,idles rough in gear
Buy a new torque converter before you destroy ******.
Been there.
1998 dodge ram pickup 318 eng. engine idle rough on warm-up engine idle rough after warm-up shutting off engine and starting back up engine also runs sluggish in over drive at a low idle. I have...
2answers
It starts fine, runs 20-30 seconds, runs rough,
check the actual fuel line. Also is it fuel injection or carberator
1helpful
Engine runing rough
This code is most likely not related to the problem, it sounds like you may have picked up some contaminated gasoline, maybe has water in it or other like dirt.
1998 Dodge Ram 4X4 Pickup
Try disconnecting the battery (both terminals and let set for a few hours) with ALL the accessorries on lights-heater-radio etc. This will draw all power from your system, then recconnect battery, it's worth a try even if it doesn't solve your problem. Bill
26helpful
11answers
99 dodge ram 1500 5.2 liter stalling on start up.
Check and clean idle air control valve
check for vacuum leaks
suspect idle air control valve
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
