Question about HP OfficeJet 6210 All-In-One InkJet Printer
I can print but cannot fax or scan?
I can print but cannot scan or fax.
  • shaabdi2001 Jan 29, 2009
    need to install the drivers for scanning printing and fax for this product
    Scholar:
  • 97 Answers
Please follow the follwoing steps,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to
printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and
then release both buttons, this should resolve the issue.
Regards,  raj_p5983
Posted on Jan 29, 2009
Toshiba estudio 255 Cannot usefunctions
you must connect the machine with you're computer.you want the fax you must check the you're photocopy machine have a fax board.you want the scan & printing connect the photocopy machine to the computer.(network cable)
Jan 27, 2014 | Toshiba estudio 255 Copier
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Brother (MFC-7340 FAX, Scan, Print) - Can send FAX...
Be sure to have a noise filter on the ADSL line so the line quality is good enough to send and receive faxes.
May 20, 2010 | Brother MFC-7340 All-In-One Laser Printer
IseMY Hp all in one 4355 printer is unable to scan
The HP Officejet 4355 can print, scan, copy and fax.
You need to install the printer software to print and scan. Copy and faxing does not required software installation.
Regards,
Rizwan
Feb 11, 2010 | HP Officejet 4355 All-In-One InkJet...
Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Nov 21, 2009 | Brother Office Equipment & Supplies
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Won't print
The printe will not scan or print. When I fax documents it is recieved witha balck shadow in teh background. I get error 2200 when I try to print or scan.
Apr 03, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Turn off confirmation page
log into the web administration page as administrator
choose fax/scan tab
report settings
Tx Report
choose turn on/off/if tx fail
I chose both single and multiple destinations
if tx fails
Tested scan to email and fax to bad addresses and page printed as confirmation of failure
No pages printed for successful Tx
Note - you can still manually request confirmation at printer menu
Fax/scan
fax menu
tx report
on
enter
start fax or scan to email
Nov 05, 2008 | Minolta bizhub 200 All-In-One Printer
HP COLOR LASERJET 2840
scan the report you are putting in for fax. give a print command for the scanned image/document after the scanned article is saved in the system
Sep 18, 2007 | HP LaserJet 2840 All-In-One Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
