Question about Kenmore 24032\24036 Top Load Washer
Last 2 loads didn't use fabric sofner
I just did 2 loads of laundry and the fabric softner was not used in either load and I was told that last night when my husband used the washer that it did the same thing to him. What could be the problem for the fabric softner to not be used in the cycle?
  • 130 Answers
Top load washer? check the agitator. alot of times the softner will gum up the inside of agitator and make dispensing hard
Posted on Jan 29, 2009
  • Chad Light Jan 29, 2009
When putting softner in after loading clothes, the fabric softner runs out onto clothes before washing cycle begins
The part that puts softner in at the right time might be stuck open or broke. Have it looked at or see if you can find the problem.
Jan 23, 2014 | Kenmore Washing Machines
I would like to know what laundry detergent and softner to use in my front load, and the right amount to use. I buy the H E products and some of them are really sudsy in the wash sink and I have this awful...
You should use HE detergent following the directions for that detergent. You can add liquid fabric softener. Make sure to fill the appropriate compartment to the Min line if you are doing a small load.
I've never used a washer that drained into a sink (always had a stand pipe). However, I suspect that the gummy residue is the excess softener that was removed in the rinse cycle. Try rinsing the sink with hot water after a laundry. This is part of the procedure to clean the inserts and detergent/bleach/fabric softener drawer when you get a build up in the drawer. In the future, use less fabric softener in the washer. Alternately, skip the fabric softener in the washer but use a dryer fabric softener.
The manuals for most Frigidaire appliances are available from http://www.frigidaire.com/manuals .
The direct link for the manual (in English) for the is: http://manuals.frigidaire.com/prodinfo_pdf/Webster/134609000een.pdf .
I hope this helps.
Jun 05, 2011 | Frigidaire ATF6000ES Front Load Washer
There are 3 compartments . . .
It says the 1st compartment going left to right laundry detergant and stain remover, the middle is for the soaking agent, and the last one is for fabric softner. I hope that helps!
You can download the manual online and I found the info on page 12 of the manual.
Mar 02, 2010 | Bosch Axxis+ WFR 2460 Front Load Washer
My front load washer will not empty out the fabric softner. I have taken out the drawer & cleaned it. It will empty out the laundry soap, but not the fabric softner
I have the same problem with mine. I found that some fabric softners worked better than others. I found Downy the worst, when i switched the problem seems to stop once i cleaned out the drawer
Nov 30, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore Elite spraying fabric softener all over clothes and tub
hello mam
is this softner provided by the kenmore dealer if not please getit from them because they know whish softner should be used and for the spots use descaling powder and run the machine without loading clothes.
Sep 25, 2009 | Kenmore 24032\24036 Top Load Washer
Fabric softner dispenser
Small brush and plain water. Rub, flush, repeat...
If it's clogged where you can't get a brush, pour very hot water into it. Last resort would be blowing it out with an air compressor...
May 07, 2009 | GE Profile WPRE6100G Top Load Washer
Trom Front Load Washer
I have never heard of cooking oil but I have heard of vinegar. If you have had your washer for a while (over a year) it could take several times of cleaning to get rid of the odor. Also be aware that liquid softner actually builds up worse inside the tub then the soap does so only use 1 tablespoon of softner. If you run the washer with nothing in it and you see lots of bubbles in the water you still have the build up inside the tub. The last item I've heard of is something called "whirlout" (not sure on the spellng) that you can get from a hot tub dealer.
Aug 14, 2008 | LG WD-14124RD Front Load Washer / Dryer
Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Stained clothes
there no grease in ft loading washer possible cause fabric softner
Feb 03, 2008 | Kenmore 44102 Front Load Washer
Whirlpool duet fabric softner problem
It obviously is backed up or splashed in from the wash. And if it is just water why worry about it.
Aug 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
85 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
