Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Spa heater The panel keeps reading "coming up short" Why is that and how do i fix it?
  • 125 Answers
My eclipse spa keeps tripping the breaker. How do I fix those?
Find the water leak that is causing the dead short to earth.
Mar 28, 2018 | Pool & Spa
I reset the heater by shutting it off for about
sounds like temp sensor is bad
Sep 27, 2014 | Pool & Spa
Jandy RS 6 panel not working. After pressing reset button, all lights on panel come on and there is no effect from press panel buttons. panel reads "Rev 6700 C." Have pulled out red 4-wire panel...
check wire going from 4 pin to controller see if by 4 pins wires touching or try controller with short wire by system wire sounds like shorted sometimes cut by landscapers
Mar 30, 2013 | Jandy AquaLink RS2/6 All Button Dual...
Pentair MasterTemp 400 Stack Flu Sensor Reading Stuck
check gas pressure and for clogged burn tubes unit is overheating
May 12, 2012 | Pentair Mastertemp Pool & Spa Heater Dual...
Hotsprings Prodigy Spa
Assuming there aren't any other faulty electrical components your GFCI will trip as a result of the heater element short circuiting.
Typically this happens when water infiltrates the heater element's protective outer coating and comes in contact with the internal heating coil. The culprit could be corrosion but usually it is a pin sized hole in the element which will lead to a short circuit.
When this happens the element has failed and cannot be repaired it must be replaced.
Feb 17, 2012 | Pool & Spa
I have a Aqua link RS4, now 13 years old. The pool will switch to the spa mode by itself, no human intervention. Any thoughts.
its most lke a problem called ghosting which mean your spa side remote will turn system to spa mode or turn other thing on such as the blower or heater will come on without manualy turning it on to fix this problem open up outside control panel and unplug the four connection wire hooked on a red bar plug tape the ends after unplugging so nothing will get shorted also turn of breaker as well so guarnting no shortage
Jan 28, 2011 | Jandy AQUALINK RS TELELINK KIT
Hi, the heaters blower was coming on at any given time so I replaced the control board and this fixed the problem, but now it started to do it again (the fan would come on and the temp display gives a...
You may have a bad touch pad. Older models had a vent on the top of the heater that would let in water and short out the board.You can fill it up with silicone.
Sep 28, 2010 | Sta Rite SR400NA Max E Therm Pool Spa...
Spa keeps tripping breaker shows pr
two main reasons breaker trips is the pump motor jammed [not turning]or the heater shorted out --disconnect power open access panel disconnect the lines to the heater turn on power if breaker trips than motor /pump problem if doesnt trip than heater problem can order heater replacement online or pool spa store--if motor pump check pump for debris and motor for lube if u can turn shaft or impeller oil motor and work it into bearings if still not turning possible need to replace motor unit
Apr 26, 2010 | Heritage Pool & Spa
Pentair Heater shuts off prematurely when warming spa
check gas pressure could be running out or overheating
Mar 06, 2009 | Pentair MINIMAX NT TSI IGNITER
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
148 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
