My battery died a day ago. So I took it home to charge and it would not work. The light will blink but that's the most I can get out of it. I tried charging it overnight and tried resetting it because it wouldn't even power on...
My computer wouldn't even recognize it and it's NEVER had that problem in the past....
Any suggestions?
(I can't find the receipt, just the shipping summary so I think getting help is out of the question)
I would really appreciate any help This one is actually a replacement that I bought because my Creative Zen Touch malfunctioned after two years of using it...
-   i have creative zen vision m and because its the 15GB the recovery tool on creative site doesnt help coz its not supported unless it was the 60 GB. it has been workin fine and then the battery died, i left it couple weeks before tryin to charge it up but it wont registar with my computer and the only sign of life is the power light flashin when you turn it on. its over a yr old now so i cant ask for it to be fixed, although this is not the first time its happend. it happened bout 5 months ago luckily the guy took it bck but said he just updated the software. but i dont know how becuase like i said none of the creative software updates will work for the type i have. -   Guest
May 05, 2009
-   I just charged it overnight, it was working just fine until I tried to power it on after charging it.
-   queenelves
Apr 15, 2009
-   My zen charges just fine but when i turn it on is says firmware problem? what should i do and what does it mean? :P
-   I have the same problem as Helmyman. I lost my Zen a couple years ago and I found it today, so the battery is like, completely dead and I don't have the charger but I had an ipod charger cord and it seemed to fit so I'm using that. But the damn thing won't turn on and I don't even get a blue light or anything...and my computer won't recognize it so I can't go and turn it on via computer or anything...it's pissing me off...Anyone help me!!!????? -   emokitty56
Dec 26, 2008
-   my screen flickers like an old tv on mine please help? -   Guest
I had a similar problem with my Zen Vision: M. I had let it sit for awhile and the battery lost all power. It wouldn't charge or connect to the computer. After fighting with customer support for a long time they agreed to have it shipped in for service.
I also was not able to find my receipt to send them. But I bought it at Circuit City and they are able to pull up any receipt for any purchase made with them. I suppose you could always try to try that with the retailer you purchased the device from.
Before you go to all that trouble though try these steps:
1. Connect the device to the wall charger. 2. Hold the power switch to ON. 3. Put a paper clip into the reset hole. 4. Continue holding the power switch on until the Creative logo appears. 5. Select Format All from the Recovery Mode menu. (Note: THIS WILL ERASE ALL DATA FROM YOUR DEVICE! - but it's better than buying a new device) 6. When the reformatting is done, select Reboot from the Recovery Mode menu.
Let me know what the results are from this.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Aug 01, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Here is the solution!
I bought mine and ran into the same problem. If you did not purchase the wall charger no problem. just find another gadget with a 5v output and plug it into your zen. the charging lights will imediately come on and your screen will power up.
Next go to the creative website and download the latest firmware update for your zen. mine came with 1.4x and i found 1.6x on creative's site.
Then run the firmware application while your zen is connected to the usb cable (i assume you did not plug the usb cable in) make sure the charger is pluged in as well so that you have power (very important) it will ask if you are sure about u[grading becuase the power may be low. ignore this and continue. after the upgrade is completed all you need to do is plug the usb cable in and it will continue to charge.
Had the same problem. Wouldn't charge with the Mains adapter or the USB. The blue light kept flashing. SO I reconnected to the mains charger and held the on button to On for about 30 seconds and behold the charger logo appeared and is now charging. I had not used the device in months.
I haven't used mine is 8 months and when I went to charge it nothing worked. If I plugged it in all it would show was that I had it plugged in but wouldn't charge. The reset is covered by the connection cable. I took a small paper clip and bent it and then held the connection cable on to reset it. I can happily say it worked and it is now charging! Thanks guys for all your help. TS
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Jul 09, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had this problem also, guys. If your battery is too low, you can't dock it, and if you can't dock it, you can't charge it properly. Fantastic logic, Creative. Before I ran into this issue, I knew my battery was low. I started it up and it hung on the Zen screen, great. I discarded the error as an effect of the battery. What I did to eventually get it to charge, is just plug it in with the flashy blue light, leave it for a couple hours, and check on it. There should be a black screen with a charging icon in the top-right. If there isn't, unplug it for a few minutes, then plug it back in and check on it in a couple hours. Just keep repeating this process, it eventually worked for me.
My problem now is that it still won't start. I do disk cleanup in the BIOs but it no longer takes 5 minutes, more like 5 hours. I left it overnight (left plugged in to charge after/while cleanup was in progress) and in the morning, no visible success. Anyone have any idea?
I had the same problem. You need a more different USB Cord (not the one that came with it). Using the different USB cord plug it in to a REGULAR DESKTOP COMPUTER.
It wouldn't charge with my brand new laptop (maybe the USB ports aren't as powerful?).... anyway I plugged it in to a desktop with a more powerful cord (not the one that came with it.. just another regular one) and it charged up fine!!! SUCCESS!!!! SCORE!!!!
We have sold Zen Vison M for a While and I Have foud 3 reasons for no turn on. 1 Hard disc problem 2 Firmware problem 3 Battery too low
1 HD damage could be done when you drop the Zen and you hear noises inside, some times the display just shows the Creative logo and no more. 2 the display just show the Creative logo, no noieses inside, you can tray to put in Recovery mode as metioned in the other solution and then erase firmware then reload firmware, this firmware can be donwloaded form creative page,http://us.creative.com/support/downloads/download.asp?MainCategory=213&nRegionFK=&nCountryFK=&nLanguageFK=&sOSName=Windows+XP®ion=1&Product_Name=ZEN+Vision%3AM+30GB&Product_ID=16002&modelnumber=&driverlang=1033&OS=10&drivertype=0&x=30&y=12
3 The battery too low and cant be recharged normaly, but the unit turn on and the display imidiatly says that you are conected to a power supply but but no Battery icon flashing
To solve this you have to dissamble the zen vision M then apply 3.7 V with an external regulated power supply to the battery (ther is a pad for the + and the chassis for -)for a few seconds then try to conect the Zen charger to make sure is chargin now, if is chargin you can assamble again quickly and put to charge
Just charge it up as you usually do. I found that after 5-10 mins of just the blue light flicking on and off it switched back on with the message rebuilding and after that it charged up as usual.
I'm having a bigger problem in that I followed the initial steps but somehow the firmware was accidentally deleted and now I can't upgrade it
Was this helpful?
Yes
No
Solution #10
posted on Mar 12, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
had the flashing blue light at the top just happen to me as im sitting in the computer cluster at notre dame...read this and just took a staple to push the reset button...problem solved
I lost my charger and the hood, i havent used it for months too. my question is if the ipods charger is the same one as the Zen's so i can use it for charging. another question(if the ipods charger is the same as the Zens) i put the ipods charger into the Zen and nothing is happening, not even a blue light. And when i connect the zen with a usb cable to my macbook the computer shuts down the hood the usb is on because it is drawing too much power. please anyone help meeeeee!
Was this helpful?
Yes
No
Solution #12
posted on Jul 28, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had a similar problem, when i tried to charge my Creative Zen it would only display the "Shutting Down" info on screen (and no battery charging icon), when i tried to shut it off completley it froze on me and no buttons would work. I used a paper clip as said in previous comments and it worked a treat, and also did not delete any of my music!!
Solution #13
posted on Jun 11, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
creative Vison M series Zen 60gb mp3 player display is disply the screen properly some lines are disply on the screen. please send the soultion urgently. waitinig ur reply
with regards
ajit
Solution #14
posted on Jan 16, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
yeah same for mine im going to try buying a new sinc cable .. where shall i buy it from ?
Purchase another sync cable. The cable that came with the Vision M did not properly charge the battery, but when I plugged the Vision into the alternative cable it fired up right away.
How can I tell if my Zen Vision M has a dead battery? I bought this years ago and used it briefly...
(More)
How can I tell if my Zen Vision M has a dead battery? I bought this years ago and used it briefly but havn't touched it since. When I plug it in (via the wall plug, not the computer) I can turn the unit on - I let it charge for about 8 hours yesterday but the second I unplug it, it turns off completely and I can only get it to turn back on when I plug it back in to the outlet. I wouldn't think the battery could be dead since it was probably only used for a total of 20 hours (max) but maybe because it's been sitting there unused the battery died??? How can I tell if it's really a dead battery or something else?
The screen froze 2 days ago. At some point, it finally turned itself off, but now it will not turn...
(More)
The screen froze 2 days ago. At some point, it finally turned itself off, but now it will not turn on
my gigaware mp3 has a full battery charge but when i disconnect from my computer the screen shows...
(More)
my gigaware mp3 has a full battery charge but when i disconnect from my computer the screen shows GIGAWARE and then a lock with a T in the middle and screen will go black
My Zen froze, so I hit the reset button. It gets to about 1/3 of 'rebuilding' and then freezes. Have...
(More)
My Zen froze, so I hit the reset button. It gets to about 1/3 of 'rebuilding' and then freezes. Have tried letting the battery go flat & starting again - no joy. Computer is not recognising software while it is 'rebuilding'... It's never done this before usually it resets and then goes fine.
I had the same thing happen to mine. The blue light flashes on & off, making a clicking like sound each time. My computer stopped recognizing it & when I try to hold the off switch over it just makes the clicking & flashing go slower, but nothing else happens. I don't get any screen recognition. I tried the wall charger solution & that didn't work for me either. Has anyone found any luck solving this. I really love my zen & don't want to have to go through the hassle of replacing another mp3 player.
Comment by Guest, posted on Dec 01, 2008
i wounder if i can play my Mp3 with not battery just direct from the power suplay
creative zen battery is low and charger won't power it up
Comment by Guest, posted on Jun 12, 2008
I have also the same problem. I had not used it for a while. And when I tried to turn it on I can only see the blue light going on and off. So I tried to charge it. But after 6 hours it was still doing the same. And it's still not CHARGED!! I hope my zen vision M is not broken because it's a beautiful mp3 player.
I have the same problem, I didn't use the player in a while, and when I went to use it, it said low battery so I said, okay well I'll charge it when I go home. So I have a laptop and I dont like turning it on just to charge my MP3 player (Renold) and instead of that I plug the dongle in and then my cell phone chager into the dongle, it appears to be working but ended up not working. I dont have a wall charger or elso that would be the way to go. I have pressed the reset button a few times but nothing has happened. I just keep getting the friggin blue light flashing. This is bugging me because a) exams are coming up and I need music, b) I paid alot for this and c) I dont have money to send it into the shop to get fixed. :(
This is a perdiciment.
But, when I first got the player and started to charge it, the player would not turn on but then after about an hour of charging. So I wil try that and see how it works.
It is nice to know that other people have had this problem and I still maintain that Creative destroys Apple in the MP3 player race.
My son got a vision M for christmas 2 yrs ago. I was trying to do something and wound up deleting the firmware. Now my computer doesn't recognize it when it is plugged in. How can I reload firmware into the device if the computer doesn't recognize it?
i have the same problem but theres a light flickering at the top of my zen. what does it mean? and when i plugged in my zen there is no usb thing like a noise
