Page is completely black coming out.
I clean the drum and rollers off and the first 3 or 4 copies are good but they get darker as each one comes out. Excess toner on drum.
    President:
  • Office Equip... Master
  • 990 Answers
Hello sir; No cleaning job you can do on the drum, it need to replace drum blade or drum cartridge, that's only solution.
Posted on Jan 29, 2009
Aficio 1018 dirty copies
Remoe the image unit,remove the OPC drum ,clean the opc drum cleaning blade(if necessarry change),remove the transfer unit clean the transfer belt cleaning blade,and clean the polygon glass.
Jan 31, 2013 | Ricoh Aficio 1018 Printer
Copies come through with a black streak down the length of the paper.
Remove the image unit,change drum cleaning blade,clean the drum.
Nov 10, 2011 | Minolta EP1030/1030F CS/PRO Copier
Canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Jul 02, 2010 | Canon Office Equipment & Supplies
Each succeeding copy gets darker and darker
When was the drum replace? Recently? Could it be time again?
Was it a remanufactured unit?
Regardless of all that, It sounds to me like the drum is failing.
Feb 27, 2009 | Brother MFC 4800 All-In-One Laser Printer
Xerox 412
This post is loaded. First of all, there should be 4 screws holding in the fuser. Unless you are talking about removing the 2 screws that hold the pressure and heat roller together in the fuser. 4 screws hold the fuser in the machine, 2 screws hold the fuser together. I am not sure exactly if your fuser was mounted to the machine with only 2 screws, or if that is an accurate post and you removed the 2 screws that hold the fuser frame together. Either way, I seriously doubt the noise is coming from the fuser itself.
Now, the darker section down the middle. I would suggest taking the fuser back out of the machine and looking at the black heat roller in the fuser. If it is not clean and shiney, and has a rough texture to it in the middle, that roller is bad and will require replacing the fuser.
What I am curious about is, the rest of the copy. Is the copy fine outside of the middle? If so then the fuser should fix it. Note if there is some reprint, sort of ghost print in the middle of the page.
The rattle may be the gear on the back of the drum cartridge, It is a small gear that drives the cleaning roller. Pull out the drum and look on the back, there are 2 small gears on the back . One of them may have broken a tooth and is jumping and not rotating properly.
Another problem, as I read this may be the toner cartridge not having the ink distributed properly, To eliminate the toner cartridge as the problem. Remove the toner and look at the roller on the front of the cartridge.It shoud have ink distributed evenly across that roller, No streaking, it should be a dull black fuzzy apperance across the roller.
Firstr check the middle of the fuser roller for the wear I described. Then the back of the drum for the noise, then the toner carteidge for distribution.
If its not fixed yet, let me know. We can discuss the laser and scanner issues. But those are far less likely.
You posted a good one...
Sep 23, 2008 | Xerox WorkCentre Pro 412 All-In-One Laser...
Copies come out with splotches
replace the drum. take out toners and clean inside real good. check your exit rollers to see if they have any ink on them. be sure you use genuine hp products.
Jun 26, 2008 | HP LaserJet 2840 All-In-One Printer
43 people viewed this question
jasbo
jasbo
