Question about Kenmore 22422 Top Load Washer
Kenmore 70 series washer quit on me
It seems that a lot of ppl are having issuses w/ their washers. Although I'm one of them my problems seem to be the exact opposite of everyone else's. The only thing my washer will do is spin...period it will make no effort at all to do anything else. Does this sound like a problem w/ the main timer or somthing more serious.
  • mrv8etr Feb 11, 2009
    IMO I thought it was not the tranny since it could still spin, yet I'm not an appliance mechanic so I'm sure I could be wrong. By not doing anything I ment it would not attempt to add water, or any other feature beside spin. Since it did this all of a sudden I figured it was most likely some electronics ie the timer, since it is the brains of the washer. Any info would be great, since a new timer is a non-refundable $130. I would rather not waste it on the washer.
    Problem Solver:
  • 7 Answers
This sounds like an old belt drive whirlpool washer, probally a problem with the wig wag or the tranny, maybe, nee more info
Posted on Jan 30, 2009
Hello, Have a Kenmore series 70 (capcity plus).
Note after reading a bunch of information. I went home and removed the hose from the Level Switch and "clean it", if you will and re-attached. Started a load, and bingo bango bongo, it work. Thanks for the insight.
Nov 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series slow agitator
You have burned the clutch this must be replaced
Jun 09, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore washer will not spin or agitate, it makes noise
IN BETWEEN THE MOTOR AND TRANSMISSION THERE IS A MOTOR COUPLING PART # 285753A REPLACE THAT WILL FIX YOUR PROBLEM
Apr 28, 2009 | Kenmore 23822 Top Load Washer
70 series kenmore washer
just pull it off - it's friction - fitted.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2009 | Kenmore 24032\24036 Top Load Washer
your lid switch is bad.you can take a pen and push it up and down to hear if it clicks.you may want to take it off and see if it has split.very easy to do.if you need help i can walk you thru it.
Mar 09, 2009 | Kenmore 24032\24036 Top Load Washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Hooking up a used washer
there should not be anything else. can you send a picture, because someone may have rigged it somehow.a077143.jpg
Jul 06, 2008 | Kenmore 12502 Top Load Washer
Kenmore Series 70 Washing Machine - won't drain water
look at the bottom of the control panel on the end caps and back out the two screws then pull the control panel slightly forward and tilt it back then you should see gray wires either going in the body of the washer or to a switch on the left side un plug the harness and put a jumper wire across the connector going to the control panel then try spin
Feb 15, 2008 | Washing Machines
Kenmore 70 Series Top Loan - Fill Cycle won't stop when full
Does the water stop when you push the timer in or are you having to shut the spigots off?? If it stops when the timer is pushed in then you have a problem with the pressure switch. There are quite a few tricks to axcessing your machine's components but if you are handy ill attemt to help.
Jan 12, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
53 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
