Question about Frigidaire FTF530FS Front Load Washer
Fills water & stop
HAVE HAD THIS FOR ONLY 15 MONTHS, JUST NOT RIGHT THAT IT DOESN''T WORK ALREADY.
I had the same situation but it is now fixed. Be sure your hot and cold water are both turned on, even if you use the COLD / COLD . My washer kept stopping in mid stream.Haven't had a problem in a month
Posted on Mar 20, 2009
Kenmore 70 series wont stop filling with water to start the wash cycle
Lid off, right side circular pressure switch with black hose attached. Remove end of hose, blow down to make sure not blocked and blow into switch where hose attaches. Should click twice. If doesn't click, faulty pressure switch (replace)
May 19, 2012 | Washing Machines
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
I have neptune parma toilet, which was purchased 6 months ago. It was working fine but now it has a problem with filling up. It takes a minute before it will start filling up then it makes noise like...
This is usually the fill valve. Try adjusting the water height. If that doesn't work, you can replace the fill valve fairly inexpensively with a new one at any home improvement store
Aug 27, 2011 | Neptune FB1625 Parma Toilet
No ice, water does not fill ice maker, but water flow is OK.
if Ice maker cycles and you get no water into it you have a clogged/frozen fill tube. If a broken line the water would go on your floor every 15 min. None of those indicates your refrig valve is bad. Dual solenoid water side works Ice doesn't.
Aug 13, 2011 | Maytag MSD2756GES Side by Side...
My toilet doesn't flush every time I flush it! It only flush If I pour a little more water into toilet bowl while water coming down toilet bowl! I've checked water level in tank and it was full...
I think the problem with your toilet bowl is in the tank fitting of it..you better check if the fittings are proprerly working..You also check the flapper and also the fillvalve.
If it is not good already you can replace it by buying the tank fittings at the hardware store..And you better also be check it to your plumber for the second thought..
Jun 17, 2011 | American Standard Home
Makes a squeel while filling, only while filling on the right side
The squealing is coming from the impeller seal on the water pump. You can try to lubricate the rubber impeller seal with silicone spray lubricant. If that doesn't work, replace the pump.
It the squealing goes on too long (weeks/months), the seal will begin leaking water onto the pump. Eventually, the pump will rust and short out, possibly ruining the electronic control board -- which can cost big $$.
Feb 12, 2011 | Fisher and Paykel GWL11 Top Load Washer
Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Feb 02, 2011 | Keurig B70 Coffee Maker
Frigidaire FTF530FS Front Load Washer Logo
71 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
