Question about KitchenAid KAWS850L Top Load Washer
Stops midcycle, restarts when you lean on it
Our washer stops midcycle, every time, about a quarter of the way through the wash. The only way to get it to start again is to jiggle the cycle knob, or, strangely, leaning on top of the washer. We think it might have something to do with a possible burnout on the contacts inside the cycle knob. Jiggling the knob or leaning on the washer gets the knob back in touch with good contacts inside the knob. Can I just replace the cycle knob and fix this problem?
  • Bryce Haymond Jul 27, 2007
    Thanks for your help. It can't be the switch that indicated that the lid is closed because it stops at the same exact point in the cycle every time. It's not random. So, do I need to replace the selector switch? If so, is that something I can do, or do I need to hire someone to come out and do it?
    Thanks again.
  • 51 Answers
If the problem lies with the contacts, then the knob is not the direct problem, it would be the selector switch behind the knob. Although I don't understand how leaning on the to makes the machine work. Are you sure it is not the switch that indicates when the lid is closed? Either way, Yes!! you can simply just change the switch over.
Posted on Jul 27, 2007
  • Ian Jul 29, 2007
    You can replace the switch yourself, its not to hard. When you have your new controller, just swap cable for cable. \Good luck
Why does drier stop midcycle and need 30 minutes before restart?
OH OH sounds like a bad motor with bad motor windings u can try disconnecting the belt and drum and run motor by itself see how it does then
Aug 30, 2014 | Kenmore Dryers
Keeps saying PAU
The PAU, or pause, error usually means that the washing machine cycle was interrupted and was not restarted properly. If you try to modify the cycle or start a new one before the first cycle is complete, the PAU error will appear on the display. If the washer was stopped midcycle and not restarted, the cycle must be canceled or completed before a new selection can be made. Push "Start/Pause" to allow the current cycle to finish before making a new selection, or push "Cancel" to stop the current cycle
Oct 15, 2012 | Frigidaire Washing Machines
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
Maytag Neptune Washer stops in Midcycle ... water does not drain either
This is more than likely going to be a problem with the pump.The pump is not draining water so the machine isn't progressing any further.The pump may be blocked with something or the pump is seized.
May 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer stops in midcycle and F displays, what could be the problem
washers stops in midcycle and F displays whats could be the problem
Mar 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machine stops and leaks
A Clothes Washer with the complaint "Leaks in Front" (on floor) can be;
Defective Water-Pump (Very common of non-belt models) - Many water-pumps become defective due to the constant wear and misc. items becoming lodged (coins, necklaces, shoe laces, screws, etc.) or breaking the plastic housing or connections. The water pump is fairly simply to replace and is located on the inside front of the machine.
The water pump is typically a white or off white plastic and will have (2) black drain hoses connected; one coming from the tub and the other going to the drain out the back/rear of the machine. Electric pumps with typically of 2 wires going to and connected to the pump. ** Note: When disconnecting and removing the water-pump, becareful of water remaining in tub that may come shooting/flowing out.
-C
Fremont, CA
Jan 28, 2009 | Kenmore 24032\24036 Top Load Washer
KitchenAid KAWS850L Top Load Washer Logo
176 people viewed this question
Top KitchenAid Washing Machines Experts
gbob59
Eric Taylor
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
