Question about Black & Decker T1029 Classic Chrome 2-Slice Toaster
Will not activate
When I put a bead in the toaster and oush the handle down it will not stay donw. If I hold it down it works fine. T1029
Art
2 Suggested Answers
  • 30 Answers
SOURCE: Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Posted on Aug 05, 2009
  • 63 Answers
SOURCE: The outer heating elements do not heat on my black
Pull the plug ... then remove the bottom ...see if the break is visible. You cannot repair the elements because the material used is Ni-Chrome and nothing will splice it safely.
Posted on Feb 20, 2011
Can a Fiesta Toaster #TS2012 be fixed when the lever handle won't stay down?
The inner workings are very flimsy metal. If you turn it upside down and remove the screws holding the cover on, you should be able to see a coil of wire and a latch, the latch grabs the lever on the handle. Either the latch is bent or the handle is out of line.
Jan 15, 2016 | Kitchen Appliances - Others
The outer heating elements do not heat on my black and decker T1029 toaster. How do I troubleshoot and fix the break in the electric circuit?
Feb 20, 2011 | Black & Decker T1029 Classic Chrome...
Toaster latch does not stay down on Cusinart CPT-120 compact two slice toaster
for Cuisinart cpt160: If the latch will not stay down it is because the electromagnet at the base of the toaster, which is supposed to activate when you push the handle down, is burnt out. I pulled my toaster apart and did a test of that mechanism and found that the solenoid was fried (open circuit). There are no replacement parts.
Jan 09, 2011 | Cuisinart CPT-160 Metal Classic 2-Slice...
Our toaster stopped working a little while ago, but it is outside the (presumably) one year warranty period. It's a 4 slice, soft touch black toaster, cost about £75, I think it is this model. It only...
remove from the electricity supply
remove crumb tray,
remove bottom 4 os 6 screws.
at the bottom of the toaster there is what liooks like a flat fish hook that engages with the handle when you push the handle down to start toasting. clean around this and try to get it to engage when you push the handle down, it wont stay down unless the electricity is connected but dont plug it in as you will probably kill your self!!
put it back together abd try it
if it does not work 4 slice toaster from Tesco £9.99
Nov 09, 2009 | Dualit 45375 4-Slice Toaster
Toast won't stay down when handle pushed down handle comes up immediately as if not plugged in. Plug definitely in. Used only 3 times.
take it back. sounds like the magnetic coil that holds the handle down when it is plugged in is not functioning.
Oct 04, 2009 | West Bend 6220 Slide Thru 2-Slice Toaster
Aug 04, 2009 | Kitchen Appliances - Others
GE 169137 Classic 4-Slice
have you tried to turn up the heat thermostat on the side.
Jul 10, 2008 | GE 169137 Classic 4-Slice Toaster
Problem with toaster
Did you try cleaning it? Crumbs in the works can work miracles - against you!
Jun 11, 2008 | Kitchen Appliances - Others
Toaster lever
I have sunbeam model AGW toaster level is not staying down and no power. the spring work, i want to know what part hold it down. please help or there any repair company i can take it (s. california) thanks
Dec 17, 2007 | Kenmore KTES4 4-Slice Toaster
Black & Decker T-1029 2-slice Toaster - lever broken
Main problem with these is crumbs, they get stuck between the 2 surfaces of the small electromagnet that keeps the lever down, consequently it does not stick anymore, try drop kicking it in the drection of the garbage can, this sort fright may just scare it into working again.
Aug 11, 2007 | Black & Decker T1029 Classic Chrome...
Black & Decker T1029 Classic Chrome 2-Slice Toaster Logo
50 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
