Question about Nikon Coolpix 4200 Digital Camera
Camera will not operate with USB cable connected
After two years of perfect functioning, all of a sudden, the camera will not operate with the USB cable connected. The power light does turn "on", but the lens doesn't open, the screen in back remains dark, and the Windows program does not pop open. The camera works perfectly without the USB cable connected. I can take pictures just fine. I have search the manual and followed all the steps on page 135 for trouble shooting. I have completely recharged the battery. Would a two year old battery just be starting to go bac? I have not ever replaced the battery. It operates the camera OK still.
  • Jane Roeschley Jul 27, 2007
    I feel pretty dorky......but I left the battery in the charger all night and tried it one more time just now.......and it works! I don't know if that means I was just trying with a not-well-enough charged battery, or if the battery is starting to wear out. It is a EN-NL5 which I have been using for 2-3 years. How do you know when you need to replace the rechargable battery?
  • 3 Answers
It's a long shot but it might be a problem with the cable itself, or it could be a problem with your USB ports on your PC, not supplying enough power.
Posted on Jul 27, 2007
SOURCE:
When I switch on my camera (sony rx100) the screen says usb mode connecting even though there is no usb cable attached. The message stays on the screen and the camera cannot be be used to take a pictu
if you can get to the menu on the camera see if there is an operations menu that says to disconnect the usb or to close the usb. It might just be on and not closed.
Apr 11, 2014 | Sony Cyber-shot DSC-RX100 Digital Camera...
Computer not recognising camera
You could try another USB port. I've had USB ports get loosened up on me without me realizing it. If nothing else has changed, I'd suggest trying to connect with a different USB port, OR swapping out your camera connection cable. The cable might be bad, usually from being pulled on so much.
Nov 28, 2013 | Panasonic SDR-S50A Std-Def SD Camcorder...
I am trying to upload pictures i took from my L200 Samsung camera by connecting the pc and the camera with a usb cable. But everytime i do that the camera suddenly goes off. I then look for it in '
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Jan 26, 2012 | Samsung L200 Digital Camera
I have been using my G11 with no problems for a year. Just tried to download pix and keep getting "Communication error". Checked the cord, it's fine, turned camera off and on several times,...
hi kbailey. Turn on the camera and go to the menu. find the reset function. Reset the camera. This means you are returning it to all of the settings it was at when it was brand new out of the box. Joe
Thanks for choosing Fixya!
Nov 26, 2010 | Canon PowerShot G11 Digital Camera
I've been using my Canon A85 for years.All of a sudden yesterday I was not able to download pictures from camera into the computer (running XP).Also tried the same on my portable (running XP) and it does...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Sep 07, 2010 | Canon PowerShot A85 Digital Camera
Connection of Canon Powershot SX110 IS to computer
Blame Microsoft updates. Try using a card reader to download your pics to a folder you create on your desktop.
Oct 23, 2009 | Canon Powershot SX110 IS Digital Camera...
Computer not recognizing my camera when connected
Most of the issues can be solved by either reinstalling the software or by disconnecting and reconnecting the device.
In this case we can close in on three solutions
1) The USB drive in the system is not functioning. Try connecting any other USB devices to the same USB port and check whether it works or not. If the other device works well then it could be a problem with the data cable or with the port in the camera (usually firewire)
2) The data cable used to transfer data might have become faulty.Try using another data cable if possible and still the same issue continues then try connecting another camera to the system and if the other camera gets detected then the problem must be with the camera.
3) Try connecting the same camera to another system and see whether the camera gets detected. If no, then the port in the camera is defective.
After this we can close in on which could be faulty. data cable / Computer / Camera.
Feb 25, 2009 | Canon PowerShot SD1000 Digital Camera
Camera cannot connect to pc anymore
yeah it could be the cable,try connecting it to other usb ports as well just to check if its not the usb port..
Jan 09, 2009 | Olympus Camedia C-3030 Zoom Digital Camera
I used to be able to plug in my camera to the computor and get all my pictures downloaded and now all of a sudden, I CAN"T and I need to find out WHY>??????? Thanks
normally in windows xp allmost all the makes, models, and brands of digital cameras are recognised as mass storage device, and shows it as extended drive, when you connect it to the computer via USB. If earlier it was recognising and have stopped all of a sudden ,there may be
1) defective USB cable.
2) Defective USB port in the camera
3) problem with the operating system of the computer. Try connecting it on some other computer.
Aug 17, 2008 | Konica Minolta DiMAGE Xg Digital Camera
Canon Power Shot Pro1 will not turn on
A new camera will fix problem perfectly. LOL Did you drop it? Seem like there might be a short or something similar. Had U ever play the game "Operation"? This camera need it, of cause done by the pro. LOL
Sep 09, 2006 | Canon PowerShot Pro1 Digital Camera
Nikon Coolpix 4200 Digital Camera Logo
105 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
