Question about Briggs Stratton H7159 & Stratton® 5500, 10 HP Generator
My 7.75 Hp snowblower starts, runs 15 minutes, then stops.
It will restart, but quits under load. Have changed the plug, pulled and cleaned the carb and fuel line to tank, made sure the kill switch was not grounded. After quitting, upon restart it will idle very rough with full choke, then suddenly take off again. The governor is working. I thought perhaps the gas cap was not breathing and the tank was going into vacuum, not so.. No points or condenser, just Briggs magneto. Is the ignition getting hot and has bad windings?
  • rmyoder Feb 05, 2014
    I just had the same problem with my 3hp briggs snow thrower (from 1978). I had just replaced the plug with the correct RJ19LM equivalent (Champ EZ Start), so I did not expect this to be the problem. However, I installed the Champ CJ8 that a previous owner had used and it ran perfectly. Apparently the RJ19LM was too hot, which then overheated the coil, etc. (?) This suggests the plug was too hot for the engine, even though the user manual specs this plug. Either way, my problem was solved by using a CJ8.
  • 100 Answers
Check your eingine compression, sounds like it is worn hence the rough idle and loss of power under load
Posted on Feb 16, 2009
  • 4jerryp Sep 04, 2011
    This sounds more like the coil warming up and shutting down. Let it cool a while (1/2 hour outside in winter) and it should run OK until the coil heats up again. If so, it is likely the coil.
    A warn engine should still run, since it started and ran OK for 15 minutes.
Toro Timecutter 14.38Z Model 74301 Briggs & Stratton Engine Model 280H07-0166-E1 Has NIKKI carb Starts & runs for ~ 15 minutes then stops. Will restart after 5 minutes rest and run...
Recheck spark when the unit cuts out. I am gonna guess you spent a lto of money chasing a bad coil! When a coil starts to go bad they become temperature sensitive. Time does the rest!
Dec 27, 2012 | Garden
My snowblower starts up easy but then it quits
Has it got a shutoff solenoid on the base of the carb? My lawn tractor would run fine for 15 minutes then shut off. Found out it was that solenoid.
Dec 13, 2012 | Garden
2000 Buell Blast runs great around town. Freeway speeds runs for 3 to 5 miles then out of nowhere dies. Acts like it's running out of fuel then dies. I have pulled the carb and cleaned the jets. C
If it starts up after sitting for a few minutes, (like 2 or 3) it could have a plugged fuel filter or the gas tank strainer built into the fuel valve could be plugged too. Drain the gastank anyway and change the gas with fresh. can't hurt. If it takes 15-30 minutes or after the bike cools some I would look at an ignition coil. Check to see if it has spark next time it quits.
Jul 05, 2012 | 2000 Buell Blast
Onan generator dies after 2-3 hours of running , wiil not restart rigt away wait 10 minutes starts no problem then runs for 15 minutes shuts down and keeps reapeating on 15 off 10
This sounds like overheating. These small generators don't have overheating protection, but if a low oil pressure or low oil level is present it may be the reason for stopping.
Check the oil level in the starting conditions and again when it stops. It may become under the "stop" level and after some time the precipitated oil has reached the "start" level. The same may be with oil viscosity and oil pressure.
Try to add some oil or change the oil with bigger viscosity.
Jul 07, 2010 | Watts Onan Portable Generator - 4000 ,...
I have an old (10-15 yrs) Craftsman Snowblower, equipped with a Tecumseh Snow King 4 cycle, 5 hp engine that hasn't run in over three years due to having been stored. I emptied the tank and put in fresh...
You are on the right track. Do check the air cleaner, and also check your oil level and condition. If the oil's been in there for 3 years, I'd change it.
Also pull the carb off the motor, and get a spray can of carb spray cleaner and clean the bowl, needle valve, around the float, and in any ports, jets, etc.
Drain a bit of the gas out and check to make sure you've got gas flowing, that it's clean and not blocked.Look in the carb bowl...make sure it's not full of sediment, water etc... Spray all the carb linkage and make sure it's all working freely.
While you're at it, use the spray cleaner to spray off the tip of the spark plug, and use some fine sandpaper to clean up the electrode. Then pull the motor thru with the spark plug out , but still attached to the spark plug wire and check for spark. If no spark, replace with a new one. If it's an older style ignition, it may even have contact points that youll need to clean and regap..
Dec 16, 2009 | Sport & Outdoor - Others
14sb mower starts and runs 2-4 min, then quits
The plug is breaking down.Change the plug.
Jul 24, 2009 | Garden
I just bought a 1999 Winnebago with an Onan 6500 genset. It only has 45 hours on it. It will run for 15 - 20 minutes with the AC on and then quits. It will restart after a few minutes and go through the...
a 10 year old genset with only 45hrs on it...sound like the carb may need replace. working with these rv units for 6+ years has taught me that you cannot clean one well enough to fix it. you will need a new carb. your local onan dealer can help. when new the warrenty makes known that 1hr per month under load will keep the carb clean and problem free. evaporating gas leaves deposits and eventualy plug fuel jets. no replacement parts are recommended. i've personaly worked on rv's with 200+ hous and no issues at all. hope this helps, good luck...
Jul 12, 2009 | Watts Onan Portable Generator - 5000 ,...
Snowblower runs then quits
check to see if gas cap vent is clear . its the little pin hole at the top of cap . if not clear it will cause a vacuum and stop the flow of gas ... good luck
Dec 19, 2008 | Mastercraft Garden
Briggs Stratton H7159  & Stratton® 5500, 10 HP Generator Logo
833 people viewed this question
Top Briggs Electrical Supplies Experts
John Trevino
jdthefixer
rlev_7
Level 1 Expert
Are you a Briggs Electrical Supply Expert? Answer questions, earn points and help others
