Question about Beko 24 in. D3421F Free-standing Dishwasher
Have a beko washing machine and the water will not drain! Any ideas PLEASE
  • Mark Foster Sep 06, 2013
    I had the same problem with my beko washing machine wmi71441 it was like the pause button was on and not pumping water out .at the front down the bottom undo the pump cover anti clock wise go carefully as their is a good bowl full of water in their . you will need a dinner tray and slowly let a bit out at a time so you dont flood the kitchen . then when its empty check the fan is moving. mine was sticking a bit so I turned it on and when the fan started a hair clip flew out. and its working fine now. do not try this at home kids. lol
    Scholar:
  • 123 Answers
Hi there......the water is not draining because..(a) blocked filter or drain pump....(b)...failed drain pump...(c)...bocked outlet to sink...or blocked drain hose from machine
regards Sir Galahad
Posted on Aug 23, 2009
My beko wahine machine wont drain
This Beko washing machine video will help you
Buy Paul Beer
Feb 10, 2014 | Washing Machines
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 28, 2014 | Beko Washing Machines
Water wont empty from my machine
Hi if your beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Nov 04, 2012 | Beko WME7247W Washing Machine
Hi - just fitted my beko washing machine after moving .Disaster!! When the water began to fill it come straight out of the bottom through a disconnected 10mm black hose about 300mm long .One end was...
a 10mm pipe is not the main drain pipe. The 10mm black pipe is for manual emptying and should have a blue stopper to plug the end, pull off the front bottom panel, and there should be a small opening, inside this opening is the manual drain pipe. Check to see that the blue stopper is still connected. If not, then you can buy these for less than a fiver online.
Oct 06, 2012 | Beko WME7247W Washing Machine
How to connect a beko washing machineplumb in to pipes
You need to connect the drain hose to the outlet , connect the inlet water line to the inlet of the machine and then the power to the machine from a three pin power socket.
Please check this link: Washing machine
Jul 04, 2012 | Beko Washing Machines
Beko washing machine not draining
If the drain hose is stretched too much to reach the standpipe, the hose can pitch.
May 21, 2012 | Beko WM5140W
My beko 1613 washing machine wont drain, and how do i operate the dial
Hi if your beko 1613 washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below. At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
Mar 10, 2012 | Beko Washing Machines
My beko washing machine is stuck on the end spin cycle and stops and starts a spin in short bursts.it has water in it and wont move on from this.
Hi jennyandeddy,
Most likely your washing machine is trying to drain, but cannot, and as such cannot start to spin.
Please follow my Tip below, for detailed directions on how to access, drain & clean your Drain Pump Filter (Please Note: Your Filter compartment is located at the Bottom Right):
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 13, 2011 | Washing Machines
Beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Jul 01, 2009 | Washing Machines
Beko wma520s start button flashing will
problem sorted by removing filter drain plug very slowly to empty machine of water and any blocked residue. check drain hose is not kinked. reset machine and rinse through on empty ie no washing.
Mar 31, 2008 | Washing Machines
Beko 24 in. D3421F Free-standing Dishwasher Logo
928 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Eric Taylor
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
