Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
Can't get front wheel back on lawn tractor Craftsman 52-inch
I took the front wheel off my 52 - in, lawn tractor to repair it and I can't get it pushed back far enough onto the axel to get the retaining clip back on.
  • 49 Answers
Make sure you are putting the wheel on the right way. The rim may be off-set. The longer part of the hub should be on the inside.
Posted on Jan 30, 2009
Front wheel alignment
Wheels are to straigten. Best to replace.
Jun 11, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman LT2000 Automatic wont move forward or backward
when you took off the bag did you pull the lever that allows you to push it around the one that puts the hydro drive in neutral its on the back a couple inches away from the eyelet you can tow with it should be released forward
Mar 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you fix the front wheel alignment on a 48 inch lawn tractor by Craftman. The wheels are turned to the outside. Theres no bent rods or anything. Whenthe wheels go one way in the frony. you mow the...
make sure tie rod between wheels is straight. if bent will cause wheels to turn outward. take tie rod loose at each wheel, straighten rod reinstall wheels should be straight.
Aug 21, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Front tire leaks. How do I remove the wheel for
Pop the hub cap and remove retainer. You could install a new tube yourself if you didn't want to have the tubless tire repaired.
Jul 25, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Problem for Craftsman 20 hp 42 in. Deck Lawn Tractor - ca model wheel alignment: both wheels point outwards
the bar connecting the wheels is bent. this is easy to change. just pull the pins out on both sides and lift the rod out. you can straighten it in a vise or order a new one through sears. cost about $12. our local repair shop keeps them on hand.
May 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I need to replace the two 21-inch blades on my Craftsman rideable lawn mower.
I just watched the service technician change mine. He pulled the rear differential release out, then after removing the hood, he put a hoist on the front and stood it upright on it's rear wheels, and easily replaced both blades with a socket wrench. That beats all the work of removing the deck and turning it upside down.
Apr 21, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman Lawn tractor - When turning to the left the Left front wheel turns much farther then the right front wheel does on a hard right turn. Almost perpendicular to the tractor. Busings are brand new....
I've noticed this on other Craftsman and MTD mowers. The ones with the one main steering rod from the steering wheel to the left wheel and a connecting rod from the left wheel to the right wheel. I think that since we are advised to mow in a counter-clockwise direction, they design the mowers to turn tighter towards the left. It's in the design just like you suspected.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding lawn mower wheel toe needs adjustment.
put it in reverse ton the wheel to the right and hit the wall again....or ir you were backing up when u hit the wall runn into foward
May 19, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Trans dose not work since i replaced rear tire on lt 1000 tractor
Similar thing happened to me . There is a half moon "key" that slides into a groove in the axle. Sounds like that fell out when you took off the wheel. Look around where you took the wheel off to see if you can find it. If not they're not very expensive at a repair shop. I did not know this & I took in in to the shop. Luckily they only charged me for the part.
May 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
are you putting it on backwards or opposite the way it came off maybe
Jan 29, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
189 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
