Question about Adesso (CYBERTABLET6400) Graphic Tablet
My adesso cybertablet 6400 tablet was working for a while then it stopped, but whenever i stop using it for awhile it'll start to work again, but after it'll freez again. I am getting annoyed by this since i have to keep restarting and it happens alover again, and i already re-intalled the driver numerous times.
  • harvey avann Jul 28, 2007
    I followed your steps, but when i got to the device manager it doesn't show "cybertablet 6400" so instead i went to search and found it to be called "HyperPen". I went to it's properties but it did not have the Power Management.
My suggestion is to try replacing the pen tip (nib). This prode=uct shoudl haev come with 3 replacement nibs and a small metal nib tweezer. Simply take the tweezer and use the slight divit in one side of it to grasp the pen tip, then pull the tip out. Soetimes a little force is requiered to get ti out. then put another one in with this same method. :D This sounds similar to a problem i had a while back and I figured out that this was the cause. I hope tis helps!
Posted on Jan 29, 2010
I would recommend turning the Power Saving features OFF in the Device Manager for your tablet. On your computer click on Start, Control Panel, System, then the Hardware tab, then Device Manager. Now find the CyberTablet 6400, right click and select Properties. Click on Power Management and be sure that "Allow the computer to turn off this device to save power" is UNCHECKED. This way the computer will not shut it down when you haven't used it fo a while. Hope this helps. Good luck.
Posted on Jul 27, 2007
SOURCE:
Can I use any type of pen with this device or does it need to be the one that came with the origninal debice?
RTM. What does the manual say? Do you need a new pen, you can probably get one from Amazon.
Feb 24, 2015 | Adesso (CYBERTABLET6400) Graphic Tablet
Tip
Pen pressure problem with illustrator
Is there anybody here who is familiar with the Adesso Cybertablet 8600?
First I'll say that despite Adesso being a cheap brand, my tablet has worked great for me for the past two years and I am happy with it. However, I cannot get the tablet's pressure sensitivity to work well in Illustrator CS2. When I go to the brush options, the pressure feature is off. Has anybody else experienced and/or conquered this problem?
Thanks
on Feb 19, 2008 | Adesso CyberTablet 6400
Adesso Cybertablet M14 Dead Spot?
clean round the edges as you probably have a bit of dirt or spilt drink affecting it
May 12, 2014 | Adesso CyberTablet M14 Media Graphics...
My mouse is not working for the adesso cybertablet 6400 but the pen works fine, would you know how to fix this?
most laptops have two parts the mouse touch board and the youch pad one of these will have to be replaced
May 18, 2010 | Adesso CyberTablet 6400
My pen suddenly doesn't work, but the mouse does.
Hello there...an adesso huh? make sure you have fresh batteries and that the pen nib is seated properly.
Nov 27, 2008 | Adesso CyberTablet 8600 (F94321)
Adesso CyberTablet 8600 glitch
I've had this problem haunting my tablet for so long! Seeing your problem here made me want to bring it back up to my attention and fix it... and I did! This worked for me at least!
Right click 'My Computer' and go to Properties.
Goto > Hardware
At the Top go to the Hardware Manager
Look at your human interface drivers installed, when I plugged in my tablet, there were two drivers installed, one called Cyberpen and one other, I disabled the other (right click > properties) and restarted the computer and now its working!
Hopefully that can help everyone else out there!
Oct 28, 2008 | Adesso CyberTablet 8600 (F94321)
Mouse works, pen doesn't
before you replace the pen. i'll suggest to check it again twice. check if theres a battery or some possible device to configure it befoire you replace the pen. thanks
Mar 28, 2008 | Adesso CyberTablet 6400
Two cursors on Vista
try this and see if it works
http://cpnmouse.sourceforge.net
lots of people says it works but i cant get it to work
Jan 26, 2008 | Adesso (CYBERTABLET6400) Graphic Tablet
Two cursors when driver is installed on Windows Vista
Below is the full text of an email I sent to the Adesso Company. They sent me a response in just a couple of days.
I tried it out on an Adesso 8600 Cybertablet. It works perfectly.
Complete email below this line:
Please install the following driver from the following link pertaining to your operating system.
Windows Vista - 3.14.09 (4.15 MB)
Windows Vista 64-bit - 3.14.09 (4.15 MB)
This will resolve your issue.
Thank You!
[email protected]
Adesso/ ADS Tech Support
Toll Free: 800-467-1195
Compoany: 909-839-2929
Adesso Inc www.adesso.com
ADS Tech www.adstech.com
Sent: Tuesday, November 11, 2008 8:31 AM
To: [email protected]
Subject: cybertablet 8600
I have had my cybertablet about 6 months. It works fine on my old computer but not on my new vista computer. I downloaded the new drivers from your website that say Vista on them but I still get a double cursor. I have found that many people on internet forums are having this same problem. Are you going to make a vista compatable driver for the 8600?
Oct 27, 2007 | Adesso Cyber 8600 10-Pack (CT8600A)
Open Questions:
Adesso Cybertablet 6400 Graphics Tablet not working I have an Adesso Cybertablet 6400. I have had it for a while and am very careful with it and i never put anything on its surface (aside from pen pressure of course.) However, I have had a few problems here and there. I have had the tablet pen seemingly get stuck on right click mode without me ever touching the side buttons and it would get stuck on things such as the crop mode for Photoshop and whenever I clicked on any links it woudl right click on them. I eventually figured out that my pen nib needed replaced. So, I did exactly that. (also, a second nib replacement problem i had was when my pen thought I was pressing down whenever I was just scrolling over the area with my pen, but anyways) NOW, I have the problem of as soon as I plug my tablet in to my computer, I can take the pen and scroll around with it ("mouse" over the surface area of the tablet without touching down) but as soon as i click down on somethind it stops working. Not only does it not register that i clicked something, but the tablet will no longer "ouse" over anything nor will t register that i even have a pen going over it. I don't get any messages saying this or anythign but i just dont have response from my tablet. Some info regardig the problem: - green light on tablet is flashing like it is supposed to - when this problem occured, i was in the middle of using it, so it's not like it was bothered and i didn't know about it because it was working fine. - right before this problem, it was acting like my nib replacement problems i had. - i tried changing the nib, but that had no effect PLEASE. I am direly wanting to use my tablet and i CANNOT figure out how to fix it, or even if this is possible. Thanks for reading my long story of a question.
Jan 29, 2010 | Adesso (CYBERTABLET6400) Graphic Tablet
Adesso (CYBERTABLET6400) Graphic Tablet Logo
233 people viewed this question
Top Adesso Computers & Internet Experts
Ekse
Edward Easley
Edward Easley
Alun Cox
Are you an Adesso Computer and Internet Expert? Answer questions, earn points and help others
