Question about Whirlpool Duet GHW9150P Front Load Washer
Dark dirty spots on some clothing items appears on every load.
The cloths go in with out dirt spots and then come out with dark grey stains
  • DRRXR May 11, 2010
    What is the age of the unit? What is the drum made of and is there rusting?
  • Anonymous Mar 14, 2014
    after I run a load I have dark flakes in my clean clothes, so really they are not clean. where are these flakes coming from, is there a space I need to clean that I am not aware of?
  • 318 Answers
What you are seeing is suds getting back onto the clothes. make sure you are using HE type soap and not using too much of it.
if you are seeing suds inside the unit, when it is running, then it will "re-deposite" dirty soap residues back onto the clothes.
you need to run a rinse and spin cycle or even a heavy duty cycle with hot water to rinse out any soap that is left in the unit.
not a major problem, just use it differently and it will be ok.
Posted on Jan 31, 2009
Large dark brown spots appearing after washing
Normally a washer does not cause a staining problem, but If something inside the washer has rusted, it could. I would check your water tank. Drain water from the drain cock at the bottom of the tank, and see how dirty it is. If it is dirty, you need to drain the water until it is almost clear.
Aug 13, 2015 | Frigidaire ATF6000ES Front Load Washer
Washer leaves stains on clothing
Many times when we cook in the kitchen, we get splattered with oils that aren't easily visible. Very often these oil spots pick up dirt from the wash water. These stains don't usually get noticed until after the clothes have been dried. The best thing to do is to rub detergent or stain remover right on these spots and let them sit about half an hour. Then rewash the clothes in as hot water as the material can take afterwards.
Aug 11, 2008 | Whirlpool Washing Machines
CLOTHES COMING OUT OF WASHER WITH DARK STAINS
Hi Lynn, this is AP.
I understand you are seeing stains and lint on your clothes once removed from your top load washer, model FWS833A. There could be several culprits causing this to happen. To confirm, are the stains not being removed during cycle or do you believe the washer is the cause of the stains? If you believe the stains are being caused from the washer it could possibly be undiluted liquid fabric softener poured directly on fabric. Something more serious could be a broken transmission causing oil to leak in the tub.
There are some basic troubleshooting tips for lint to check such as undissolved detergent can leave residue on clothing. Separate clothing items which shed lint from items which attract lint. Permanent press, synthetic, knit and corduroy items will pick up lint from towels, rugs and chenille bedspreads. Make sure to Use correct amount of detergent, water temperature and water level.
There are some simple troubleshooting tips listed above and in your owner's manual, if you find they do not resolve your concern I would recommend contacting a local authorized technician to inspect the washer.
Thanks,
Mar 30, 2014 | Frigidaire FWS833A Top Load Washer
Grease-like stains on clothing
hi. i can help. the grease is coming from one of two places. Either some item with grease on it got placed in the machine and the grease transferred to the tub where it will cause the problem until it is spotted and removed with a degreaser, or wears off.
OR the grease is coming from the washer itself. Perhaps some grease oozed out of the mechanicals related to the aggitator.
Either way I would get a strong flash light or trouble light and look carefully in the tub and around the aggitator for grease. Then remove it with a cloth and some degreaser, available at any auto parts store.
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Oil-like stains on wahsed clothing.
Around the white plastic rim right above the steel tub, link gets caught. I have only been able to remove it with my fingers every week or so and this seems to stop the "spotting/striping" of stains on my cloths. I would also like to know the RIGHT answer to this one. Thanks
Mar 28, 2009 | Speed Queen AWS52NW Top Load Washer
Kenmore Elite calypso 21086 leaves dirt streaks on clothes
Run the hottest & fullest cycle possible - without a load - and add a grease remover - like goo-gone. Fatty tissues build up inside the tub - and can be released on hot cycles if HOT wasn't used very often.
It is recommended to run a HOT load every 2 weeks or so to avoid these buildups and staining of clothes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 20, 2009 | Kenmore Elite 21086
Dark Grease stains on my Kenmore Front Loading washer
THE SEAL IN YOUR TRANSMISSION IS GONE. NEEDS TO BE REPLACED.
Dec 13, 2008 | Washing Machines
Oil Like Stains on dark cotton Clothes - Whirlpool duet
Problem Solved !!!
Ok, I had to stop and tell everyone about my latest experience. When we moved here we bought the nice Whirlpool front load washer and dryer set. I Love them....still don't understand how my clothes get clean with so little water, but love them. ..................That is until lately. I was really upset about a total of 4 white blouses that looked to have some kind of light splattered stains on them after washing. I would try to wash them again with a stain remover sprayed or scrubbed on the spots, but they wouldn't come clean. I gave up and considered the blouses ruined. I told William what was happening and he called the repair man out because he thought it might be some kind of part in the machine that was leaking oil onto the clothes when they were washing. The guy came out and told William that there wasn't anything that could go into the washer tub and get onto the clothes. He then looked around in the washer and at the little detergent dispenser drawer. He suggested that we use 1 cup of Clorox and 1/4 cup of dish washer detergent (cascade with dawn degreaser crystals) on a hot to medium water temperature and turn it on a complete wash cycle to make sure that we didn't have mold and mildew setting up in our machine. After he left, I proceeded to do what he told us. I though.....the blouses are probably ruined anyway. I had tried to get out all the spots to no avail, so what the heck......I threw them into the mix too! Would you believe they came out clean, very bright white (instead of yellowed or dingy from continued wear) and the washer smells as sweet as it did when it was new. Why didn't they tell me about this when I bought it ??????????? I plan on putting the detergent mix in the washer every couple of months and throwing in all the whites that I can find to take advantage of the cleaning effect on the whites. (I thought that maybe some of you had gotten stains on white clothes that you would like to get out too)
Dec 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
685 people viewed this question
Dan Webster
Dan Webster
Sal De
