Question about Kenmore 24032\24036 Top Load Washer
What does the F stand for on my wahing machine?
My washer fills up, starts to spin, stops & an F comes up. What does the F stand for? I push stop, then start & it will run for a minute then repeat the process.
  • onthethejob1
    onthethejob1 May 11, 2010
    f what thats a error code,,but it has to have more to the code ,,,
  • 15,935 Answers
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes:
* Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
* Check the MCU
* Check the Wire Harness
begin troubleshooting right at the motor. Why start there? Because the motor is one of the prime suspects and it's easy to check. Remove the back panel and unwind the belt from the drum pulley. Now turn the motor pulley (sans belt) by hand. If it doesn't turn smoothly and easily, you have a bad motor.
If the motor pulley turns smoothly and easily by hand, next step is to run the motor with the belt still removed from the motor pulley. If the motor seems to run fine that way, put the belt back on and run it again. If the motor won't run under load (with the belt on), then that's another sign that the motor is bad.
Suppose the motor turns easily and freely by hand but won't run either with or without the belt. This is a more subtle condition because we're probably dealing with a bad MCU or flakey wire harness somewhere between the motor and MCU, or between the MCU and the CCU.
One trick that often works at this point is to remove and reinsert all wire connections at the board and motor. This tends to clean the small amount of corrosion that will build up on the connections. After you do this put the machine into a service cycle (see the instructions in the tech sheet found inside the unit or you can ). Part of the service cycle is running the motor at certain set speeds which checks the tach.
If you've removed/reinserted the wire harnesses and still no joy, then usually the problem is the MCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Maytag washer fills and washes but doesnt rinse or spin.
i would check your water level switch function, it will be located at the end of a 1/4 inch flexible tubing coming from the washer drum, my past experience indicates the replacement of this assembly will restore operation to your unit.`
Apr 16, 2012 | Maytag Washing Machines
The lights are coming on but nothin is happening what do i do ?
wahing machine must of filled but then stopped on wash wont spin or rinse lights all on any ideas
Mar 13, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Front loading ge washing machine only 2 months old. door locks,
take water lines off of water valve at rear of unit and clean dirt out of screens.
Jun 19, 2009 | GE WSXH208A Front Load Washer
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Kelinator ESC wahing machine spinning ok but filling too slowly. Not doing wash cycle
If your washing machine is filling too slowly, then you probably have a clogged screen on the back of your washer. To check this: Turn off the water supplies(both hot and cold). Remove the hoses at the back of the washer. Check the screens for debris(i.e. rust, dirt, scale, etc.) The screens will be pushed into the back of the washer where the water enters the washer. Debris can come from a variety of places: #1 Deposits coming off the sides of your pipes.(Older homes) #2 Repairs done to your plumbing lines, or the cities lines.
If these screens are clear of debris, I would then check the water flow out of the hoses. Take each hose with the end pointing into a bucket, and turn on the water to allow a full flow. This will also flush each line of debris. There could also be a number of reasons that there would not be full flow out of the supply lines: #1 Debris stopping up the line at the shut-off is one of the main causes.
If you have debris stopping up your screens and shut-offs, it will most likely stop up your aerators on your faucets, and your shower heads too. It is also suggested that you check these.
If you are getting debris in all these items, I would recommend that your lines get flushed. You can do this, but many times it is easier to have a plumber do this. If you do not know what you are doing, it can get very wet, and time consuming.
Good Luck
Jul 28, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
29 people viewed this question
Sal De
fordexpert
Robert Rankin
