Question about Philips 32PFL3403D/27 32 in. LCD TV
No audio output on Philips HDTV Model 32pfl3403
I am trying to connect an ''I live'' soundbar, tested it on 2 other HDTV's;
works great. I have hooked it up to AVI, AV2 audio red/white jacks
on Philips 32pfl and NO GO.
What am I missing here?
Thank you for your help.
    Problem Solver:
I HAVE A ILIVE SOUND BAR,YOU WILL HAVE TO HOOK IT UP THROUGH A POWER SOURCE WITH YOUR RCA CABLES I ROUTED MIND THROUGH DIRECT TV RECEIVER. WORKS GREAT. HOPE THIS WILL HELP YOU.
Posted on Jun 15, 2009
No sound via philips soundbar hts8100 with philips 52pfl7403d tv
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Sep 09, 2016 | Philips Televison & Video
I bought a wireless soundbar to hook up to my Smart flat screen tv, and the manual does not state anything on how to really do it...too simplistic and not enough info for one.
Find the Audio Out connections on your TV and run the dual RCA cable (Red/White) to the Input RCA jacks on the back of the sound bar unit. You may have to go into your Audio or Sound menu on the TV and turn off the TV's speakers in order for the Audio out on the RCA output to turn on.
Feb 23, 2016 | Ematic ESB212 Wireless SoundBar with...
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Jan 24, 2015 | Sharp Aquos Televison & Video
I have a Philips soundbar that I have hooked up to my flat screen tv using audio (red,white) cables directly from soundbar to tv and there is no sound coming out.
Be sure you are hooking up the Audio Output from the TV or satellite to the soundbar.
From the satellite box both Audio Output and Video Output go to the TV, and then Audio Output from the TV goes to the soundbar.
Or
From the satellite box Video Output goes to the TV and Audio Output goes to the soundbar.
This may help as well:
https://www.youtube.com/watch?v=Z27WtBy4IUs
Jan 07, 2015 | Philips HTL2101A/F7 Soundbar 40 Watts
Can a soundbar an sub woofer be hook to Lt 52133, 07 model. if so how and what product #.
Yes! Use the digital audio output from the Mitsubishi TV to the soundbar! You need a digital audio cable that usually comes with the soundbar!
Dec 30, 2014 | Mitsubishi LT-52148 52 in. LCD HDTV
Do i need to buy anything extra for my ilive 37' soundbar for my tv? The sound doesnt work with my tv, but the bluetooth works just fine.
You'll need some sort of audio cable to connect the TV's sound or audio output to the soundbar. For the most basic connection, use an RCA-style cable ( like the one found here: http://goo.gl/5F8yLh ) to connect your TV's audio output to the soundbar's input. Most soundbars also have an SPDIF input ( like the one found here: http://goo.gl/2F2rKs ) and most modern TV's have an SPDIF output. Get an SPDIF optical digital audio cable to connect the two devices together. Once you've decided which type of connection to use and have connected the TV's audio output the soundbar, then make sure you select the proper input on the soundbar. That should fix your problem.
Nov 28, 2014 | iLive 2.1 Channel Sound Bar ITP152B
I have a proscan with no sound so I brought a
You hooked up the sound bar to the cable box red & white sockets, right. Now you have the soundbar hooked up to the TV red and white sockets. Did you notice any difference with the labeling on the two sets of sockets? The cable box sockets were labeled "Audio Out", but the TV sockets are labeled "Audio In"
AV signals are directional. Any socket labeled "Out" will give a signal from it for connecting to another device e.g. the connection from the cable box to the soundbar.
Any socket labeled "In" is designed to accept a signal from something else, but it won't give a signal out. So you can't connect the TV's Audio In socket to the soundbar's Audio In socket because both expect a signal from something else and neither supply a signal out.
Check the back of the Proscan TV. Is there a socket labeled Audio Out? If so, use that.
Sep 03, 2014 | Televison & Video
Want to hook up a philips sound bar to my t.v. what cable do I need and where do I plug in at
Which model TV and which model sound bar do you have? Some Sansui TVs have a coaxial digital audio port and a 3.5 mm headphone port; this is true for the SLED2480. Some of the smallest Sansui TVs may only have a headphone out option or no audio output. These jacks will be on the back or the side depending on the model. For some Sansui models, these will be easiest to see when you put the TV on its face (on a clean soft surface) and look next to the base of the TV.
The Philips CSS2123B/F7 has a digital coaxial port, a digital optical port and RCA analog inputs on the back of the unit. It also has a 3.5 mm input on the right side for connection with auxiliary devices (like a headphone out). Other models may have different ports.
Thus the cables you need will depend on the specifics of your devices; similarly the locations of the ports will depend on the models. If your TV only has a headphone out and the soundbar has analog audio inputs, you will probably want a 3.5 mm to RCA audio adapter. There are several options depending on whether you want to use an 3.5 mm audio cable or an RCA audio between the TV and the soundbar. (Pick a cable and then get the adapter to plug into either the TV (M 3.5 mm to RCA FF) or the soundbar (2 RCA MM to 3.5 mm F).) There are 3.5 mm M to RCA MM cables as well.
If your TV has an digital audio outputs, get the correct cable (optical or coaxial) and connect that to the port on the sound bar and TV.
Please add a comment with the model of your TV and soundbar for specific information. I hope this helps.
Nov 30, 2013 | Sansui Televison & Video
Philips 32PFL3403D/27 32 in. LCD TV Logo
1,960 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
