Question about LG 42LC2D 42 in. LCD HDTV
Sudden power failure
I am having trouble with my Swisstec S19/8 television. Upon turning the power on, assuming it is plugged in, the television light is supposed to glow red for standby, which then turns green upon pressing the power button. Yesterday, I could hear crackling when I turned the power on, and the red light disappeared completely even though the power switch was on. I was able to fix the problem by repeatedly turning the power off and on, but I could still hear crackling after a few tries. There was no crackling when the television was on. Today, I experienced the same problem. I switched the power on, but heard crackling and the power failed. I tried a few times, and successfully turned the televison on, but after a few hours, the power failed. After this, I could not switch the power on at all. I could not get the red standby light to appear. I have had the television for a year, so no longer have the packaging, so could not call the support line.
My swisstec tv had exactly the same problem this week march 30th and the 12 month warranty expired.....i went to skymediauk online and extended my warranty ..free for 3 months they collected it,fixed it and returned it in 46 hours
Posted on Apr 02, 2009
Model 85610 shut off and won't turn back on
  • Magnetron failure
  • Door interlock failure
  • Control board failure
  • Internal fuse failure
Jul 22, 2017 | Kenmore Microwave Ovens
Replace fuse power cord board blown
hi, there seems to be dead short somewhere i'd unplug all the leads from the power board and plug one in at time, then power up the set to see which board is blowing the power supply hope it helps
regards
shaun
Feb 01, 2014 | Mitsubishi WD-65737 Home Theater
My swisstec tv won't turn on and I'm sure it's
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_2_2012_12_08_41_am.jpg
Apr 01, 2012 | Televison & Video
Protroniq 32" LCD pltv-3250 no
Yes you can replaced it on your own..
just open the back cover and replaced the bad power supply board...its very easy just like plug and play..
Thank for using fixya...
Aug 06, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Swisstec 20'' keeps turning itself on
Hi All,
I have a similar problem with a Swisstec 32" LCD (older than 3 y.)
I decide to open it. Unconnect and re-connect the on/off button PCB. Then the TV don't switch on/off anymore. If you have a better solution please let a message.
Jan 20, 2009 | Televison & Video
LG 42LC2D 42 in. LCD HDTV Logo
362 people viewed this question
Computer Repairing
Computer Repairing
