Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Need a manual to show me how to put on a belt. None of the pic
None of the pictures was mine. It is an upright with bag and it is a kenmore whisperton model 116.36312691. Please tell me where I can get a manual.
reddevil6
  • 1673 Answers
SOURCE: Kenmore Whispertone
The cover over the light, push in on the sides to release the tabs, then remove 2 screws. Using a screw driver, put it in the slot, one on each side, from the bottom, pry up to release the tabs, cover will come off and you can get to the belt and brush roll.
Posted on Jan 14, 2008
  • 184 Answers
SOURCE: Need new power brush
Hi let me try to find that part for you. I assume color will not be an issue. will get back to you as soon as I can
Posted on Feb 20, 2008
  • 6 Answers
SOURCE: Kenmore Elegance Upright Bagged Vacuum Belt Broken and Smelling
It sounds like the brushroll has caused your belt problem and will be the cause of your burning smell as well. What commonly occurs is that carpet fiber,hair,string, thread,etc got wound around the brushroll and some will get caught in the end caps which is where the bearings are.The end caps need to be removed and cleaned so that the bearings can allow the brush to rotate freely.Check that there is no melting of the end caps or the base plate where the end caps fit into the machine._Good Luck
Posted on Oct 26, 2008
  • 86 Answers
SOURCE: Kenmore Upright Model 116.356224400. Belt
A picture is worth a thousand words, so the diagrams in this manual should be helpful:
35622 Owner Manual
Posted on Feb 08, 2009
SOURCE: Need to check belt on a Kenmore WhisperTone powermate vacuum
There are two screws. Pry off the light bar on top by pushing against the sides, and you will see them inside just behind the light bulb.
Posted on Jul 26, 2009
Power but not sucking up..
You have to check two thins 1 that none of the hoses or filters are clogged on the unit. This is not always so easy but the entire run of the hose till the bottom must be clear. 2 You have to have the door th the bag closed properly. If there ais any opening you will lose suction to that opening
Dec 14, 2010 | Kenmore 31913 Progressive Direct Drive...
Manual for Kenmore Progressive Direct Drive Upright Vacuum
can some one show via picture of the location where the micro switch is where the hose attaches to the progrssive direct drive vacuum cleaner to get the start brushes rolling again,
Sep 28, 2010 | Kenmore 31913 Progressive Direct Drive...
Belt is broken
there is no belt on your model there is a reset button on the side by the brush
Dec 13, 2009 | Kenmore 31913 Progressive Direct Drive...
I have a Kenmore Progressive Inteleclean Upright vacuum cleaner (with Bag) . It has good suction only through the hose now and none through the bottom for cleaning carpets. and, there is a noise like it...
Theres a little bendable neck that hose with suction plugs into. Thats the one thats clogged. You will have to fish it out by taking off the roller and clearing the clog.
Sep 22, 2009 | Kenmore Progressive Bagless Upright with...
My Oreck XL was working fine, then when I vacuumed a shag rug is started smoking and smelled like something is burning. (I changed the bag, checked for clogs--none found, and roller brush is turning. It...
Even though the brush is spinning, the belt is probably worn out and stretched. when you vacuum the shag carpet, it puts more drag on the brush. try running it on a shorter carpet or hard floor for a few minutes. if it doesn't smoke, then you know it's your belt. if it does smoke, then it's probably the motor burning up.
Jim
Jun 02, 2009 | Oreck XL2000 Bagged Upright Vacuum
Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
May 03, 2009 | Dirt Devil SwivelGlide Bagged Upright...
No suction for u4264-930
This link at the Hoover site is a general manual for the older uprights. It shows how to replace belt etc. Mine is a "Soft & Light" and it worked for me:
http://www.hoover.com/pdfs/manuals/C1404.pdf
Dec 23, 2008 | Hoover Soft Light Supreme U4262-930 Bagged...
Lost my user manual
Can't find manual. Belt broke, replaced it now no suction. Have checked for clogs none found.
Jul 26, 2008 | Hoover U5018-900 Bagged Upright Vacuum
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
65 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
