Question about Franke Saphira Espresso & Coffee Maker
Water leaking from what looks like water pump on end of pump is what looks like a black diaphram thingy water is weaping from both pumps. are these fixable where can i get parts and how do i fit them
I could come and have a look at this problem for you, email me: bean2cupservices@live.co.uk
or call me 07732 590699
www.bean2cupservices.com
Posted on Jul 08, 2009
When does the water pump need replacing
A qater pump usually starts leaking from a small hole in it called a weap hole. When you see coolant leaking from the pump its time to teplace it
Sep 27, 2014 | Cars & Trucks
Bad water leak,looks like it's comming from around the belts .water pump?
It sounds like the water pump is leaking from the weap hole.
Double the hode connections, and hoses. If they look good then it most likely need a new wayer pump
Nov 26, 2010 | 1997 Geo Metro
Water pump is leaking
If its leaking from a mount bolt then your gasket went bad.....get a new gasket and some permatex
However if it looks like it is leaking from the pully its self then it is leaking from the weap hole, when this happens it is because the seal arround the berrings has gone bad. You have to get a new water pump
Nov 27, 2009 | 1998 Chevrolet Cavalier
Leaking coolant from around water pump just put in new radiator on monday and no leaks from it or hoses, think is weap hole in bottom of water pump.
If it's the weap hole the pump is going bad. That hole is designed to leak as a "warning" that the pump is going to fail.
Oct 29, 2009 | 1997 GMC Yukon
Leaking coolant from crank seal on 1991 toyota sr5 4x4 pick up. i figure the water pump has a seal gone behind timing cover and no other leaks it over heated today at highway speed .
THE WATER PUMP HAS A WEAP HOLE ON THE BOTTOM OF THE HOUSING THAT INDICATES PUMP FAILURE BY LEAKING WHEN THE PUMP NEEDS REPLACING. IT IS TIME TO REPLACE THE WATER PUMP. IN ADDITION YOU MAY WANT TO REPLACE THE TIMING BELT AS WELL WHEN YOU REMOVE THE TIMING COVER AND CRANKSHAFT PULLEY. I HOPE THIS CLARIFIES ANY QUESTIONS YOU MAY HAVE. THANKS FOR USING FIX-YA AND FOR ANY COMMENTS YOU WISH TO SHARE. PLEASE KEEP ME POSTED. GOOD LUCK
Sep 21, 2009 | 1995 Toyota Camry
John Deere 445 lawn tractor is leaking coolant
This model has a weap hole just under water pump.If it leaks enough it will stain front cover just to the side of crankshaft.Do not buy the rebuild kit,just replace pump.
Apr 18, 2009 | Garden
Coolant leak underneath, 03 h2. could thhis be a water pump since i couldnt see any leak from radiator or any hoses
Could be the overflow canister or a seal in the front of the engine. Have the system pressure tested to be sure of the origin.
Feb 25, 2009 | 2003 Hummer H2
Franke Saphira Espresso & Coffee Maker Logo
131 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
frankecoffee
Level 1 Expert
Jay Finke
Jay Finke
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
