All bearing is jam,and the belt is ok wtf??
Old post, but Ill answer for others. with same issue, belts.
Timing.
no country stated. so.... ?
what engine.? there are 56, and many cars have 8 engines used
on one brand car.
I live in the USA< and go to to any store that sells GATES belts.
Napa is my best store,
and GATES has a full kit ,with the best belt and a new idler.
suzuki real parts , only in USA and Canada is Suzuki shutting down. (some parts sources do remain open, no all,)
your car, a Generation 2 swift
had , 5 engines offered world wide, says wiki, 1sec search
1.2 L I4 (petrol)
1.3 L I4 (petrol)
1.5 L I4 (petrol)
1.6 L I4 (petrol)
1.3 L I4 (diesel)
which might you have.???
SOURCE: Whinning Noise when cold.
Timing belts don't while because they don't slip! Could be the water pump/alternator belt.
Testimonial: "Thank you...Its a high pich whinning noise when started cold ...you can hear it especially when accelerating. goes when engine is warm:("
SOURCE: suzuki swift carburetor vacume hose installation
: www.teamswift.net/viewtopic.php?f=31&t=42440 look here good luck
SOURCE: why does the malfunction indicator light and how
There are many reasons why this light comes on, you will need to have the computer scanned for codes, these codes will tell you what the problem is and with a little testing you can repair it, many auto parts store will scan it at no charge for you, just get a printout with the codes if you need more help just let me know what the codes are they will have letters and numbers for example code could be po300, hope this helps.
SOURCE: how i can adjust clutch pedal of suzuki swift 2006
unfortunately no .... but I think you can add a Sporty Pad ,,, Which is available in most Moto shops ... If your Problem just is to increase height ...
Please Rate My answer well and Support me !!!
