Question about Brother MFC 8500 All-In-One Laser Printer
BROTHER MFC 8500 - ERROR 77 & 76
My MFC 8500 has stopped functioning! It suddenly starts beeping and flashing Error 77. Then it is stuck. Cant get the error code to clear. What is wrong with it???
Since we are a small office this is the main everything machine.. :-( help
  • 13 Answers
SOURCE: How to clear a Machine Error 76
Error 76 is fuser error, you need to change the fuser but first just in case try to reset settings to factory defaults.
Posted on Nov 30, 2007
SOURCE: Brother mfc 8500 clicking noises
If you open the cover and remove the toner/drum unit, you will see (on the left side as you remove) a small hole with two triangle teeth.
on either side of this hole are two small phillips head screws. this is the problem we had with our clicking noise. As the machine tries to turn the toner/drum, the innards of the toner are becoming harder to turn. So the part of the fax machine that fits in the hole end up stripping the teeth in that hole. If you have an old toner cartridge, you can remove the gearing from it (where the small phillips head screws are) and use it to replace the gearing on the newer cartridge. Or go buy a new toner cartridge.
Posted on May 09, 2008
SOURCE: brother mfc 9700 error 77
( 76 Heater harness disconnected or broken. Or heater thermistor harness
disconnected or broken when the power is turned on, the front cover is
opened and closed, or the machine exits from the sleep mode. )
( 77 Power turned off and on at the occurrence of error 76 or 78. )
( 78 Heater thermistor short-circuited. Or heater thermistor harness disconnected
or broken when the machine is on standby. )
Posted on Aug 03, 2008
SOURCE: document jam brother mfc 8460n
if the message refers to the scanner, open the cover of the feeding unit on top of the printer and clean it with compressed air. Most probably an insect got stuck somewhere
Posted on Nov 07, 2008
SOURCE: Drum on Brother MFC-9840CDW needs replacing less than 9 mo later.
press the 3 and 9 button at the same time in ready mode.
then the reset menu will appear, press the up or down arrow until you get to drum.
press ok,
and select 1 to reset or 2 to exit.
it will return the ready state and your done.
Posted on Feb 08, 2010
My Brother MFC-465CN is not printing anything. On print test, all that shows is 5 small squares of CYAN and 1 row and 2 small squares of Magenta, no black, or yellow. There are no error messages, and...
This is probably bad, but we can try. Brother has a cleaning function in its menus, and I'm sure you've tried that. It works by blasting ink through all its nozzles to try to clear any blockages.
It also has more advanced cleaning functions that work essentially the same, but are a lot more aggressive. You need to get into what Brother calls Maintenance Mode first:
Press these buttons in rapid succession:
Menu
Black Start
Up-arrow
Up-arrow
Up-arrow
Up-arrow
The machine will protest with all kinds of beeping. Ignore all that and keep going faster. If you stop to wait for the beeps, it won't work. Touch Stop and do it again.
When you have all the lights flashing together and MAINTENANCE on the display, you're in.
touch 7, 6, 3, Start to initiate a Power Purge, which uses three time the ink as a normal cleaning.
Wander off for a few minutes. When it's done, press 0, 9 to print the same test page you are accustomed to. If it's significantly improved, do the 763Start trick again and test again.
Exit the Maintenance Mode with 9, 9. The machine will go through it's complete start-up procedure.
If these purges don't help, you need a new printhead, and if it's not under warranty, it may cost more that a new MFC 465. If it's just barely out of warranty, call Brother's customer support and beg. They sometimes issue a work order to the closest servicing center and effectively extend the warranty by covering all parts & labor.
Feb 09, 2011 | Brother MFC-465CN InkJet Printer
Hae brother MFC-8500 and just replaced
This is an easy one. With the power on, open the front door, where you installed the drum. Press the CLEAR button. The display will ask something like, "Change Drum? Press 1 for yes. Press 2 for no."
Press 1.
Close the front door.
Feb 10, 2010 | Brother MFC 8500 All-In-One Laser Printer
Help with Brother MFC-8500 all in one printer
When you get the paper, can you smear the print with your fingers, or is printed on there properly.
if you can smear it, it would be your fuser not doing its job properly, if you cant, then its your replacement toner as it most likely incorporates the drum in it, which i think is your problem.
Jun 20, 2008 | Brother MFC 8500 All-In-One Laser Printer
Help
rest teh machine by shut off the machine and pull out the pluug. wait 2 minutes and plug in the power and turn on the machine.
May 29, 2008 | Brother MFC 8500 All-In-One Laser Printer
Brother MFC 8500 receives faxes and does nothing else
Check to make sure that the PC Fax Function is turned off. I noticed after I connected the 8500 to my PC and installed the software, I too could no longer receive faxes and it was corrected after I turned this PC Fax function off.
The function is located by:
  1. Press the MENU button.
  2. Select Option 2.
  3. Select Option 1.
  4. Select Option 8 (PC Fax) and turn that function OFF.
Hope this helps!
Apr 28, 2008 | Brother MFC 8500 All-In-One Laser Printer
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
I do not know who to operate the scanner function on my Brother MFC-8500
You operate it with paperport software which comes with the fax or can be downloaded on brothers site.
MJ
Indy
Oct 24, 2007 | Brother MFC-8500 All-In-One Laser Printer
LIGHT FLASSING CANT PRINT
Error 50: Purge cam problem. mfc/dcp has to be taken to service. No chance to fix it by yourself. sorry!
Mar 29, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 8500 All-In-One Laser Printer Logo
125 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
