Question about Amana NDE2335AY Electric Dryer
Drum will not turn but it is heating up
I took my Amana apart to clean the vent and it ran a few more times and quit. Its heating up but the drum is not turning.
  • 1,214 Answers
Pressing 5 Skips introduction, or Skips to next message.
Pressing 6 deletes current message and Skips to next message.
Pressing 7 plays telephone ID of caller if provided
Pressing 8 Repeats previous message, or repeats message
Pressing 9 Pauses or resumes message
Pressing 0 exits the messaging system.
Posted on Jan 29, 2009
  • Mark Egan Jan 29, 2009
    Oops, my error. Got my Askers messed up.
I have an Amana Dryer, ned7200tw. It was taking forever to dry clothes, took twice through per load. We replaced the heating element 2 days ago, cleaned all the lint while it was apart, and it is still...
Did you check the trap door on the outside of the house where the vent goes outside. If the door is stuck or the end of the vent is blocked you will get excessive dry time like you are having. Also possibly a thermostat inside starting to go bad and sticking.
Mar 01, 2015 | Amana Dryers
How can I diagnose, isolate and repair my Amana, NED7200TW dryer it runs but will not heat?
Since you say it happened gradually seems like it's not the heating element. If that's functioning properly you should see the orange glow inside the dryer when running. If your dryer does not have a glass door you can keep the dryer running by holding the button in. Look on the door, at some point you should see something that makes contact and pushes a switch on the frame. You can trick it by manually closing the switch. Be careful. I would suspect the trouble is a clogged lint exhaust. Over time this will fill with lint preventing the moist air to escape. This is how the dryer works. The hot wet air in the drum needs to vent outside to dry the clothes. When this becomes clogged you have nowhere for the moisture to go. So it stays in the drum and runs and runs without drying clothes. Also make sure you clean out the lint trap after each use. Clean the entire vent path. Also make sure you are venting outside. If not, you are just recirculating wet moist air back into the dryer. When working properly, you should feel a good flow of warm wet air at the outside vent. If not there is still a clog. Good luck.
Sep 05, 2014 | Amana Dryers
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Gas dryer runs but no heat
Those coils are probably getting hot and quitting then after a long time they cool off and work some more then quit again.62a13a2.jpg2720ab1.jpg
Apr 11, 2010 | GE DVLR223 Dryers
Our Amana Dryer is not drying clothes properly. It does not seem to heat up properly and takes quite a long time to dry a load. The air flow seems to be good. There is not build up of lint in the hose and...
Hello there:
Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
- If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 110 degrees and 150 degrees. Check that the drum seals are not worn out.
Dec 23, 2009 | Amana Dryers
Dryer runs ,heats up flame goes off after 30 secs won't relight
Seems to be a problem with the bas shouldve seen them in front of ignitor...will show similar signs of ignitor. part#306106 AND 306105. come off easily with a few screws and just slide over valve assembly.
Jun 08, 2009 | Whirlpool LER4634J Electric Dryer
Dryer quit after about 20 minutes-see more details below
do you have clothes on top of dryer? if so, i'll say it again never ever stack clothes or anything on top of it. Things on it insulate it and will overheat the machine. Yes it has a overheat linit switch but to get to it you have to take it apart and pull the drum out depending on the style of heat element you have. Some are in the back of drum and others are in a tube on the floor of the unit inside. If yours is behind the drum then drum needs to come out to check for the problem
Feb 26, 2009 | Amana Dryers
Blowing high limit fuses
Check the blower wheel attached to your motor.
It may be free-wheeling causing too high a temp thet is blowing the fuses.
Feb 22, 2009 | Amana ALE230RAW Electric Dryer
Maytag Dryer will not start again
Check list:
clear vent pipe
dryer clean of lint
blower wheel tight
drum turns freely
fuse tight against heater.
Wires not shorted on high limit mounted above heater
electric bill paid.
Feb 07, 2009 | Maytag PYE2300AY Electric Dryer
Amana NDE2335AY Electric Dryer Logo
78 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
